  • Guests: 23
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
Can anyone help me?
Adam Munich
Sat Nov 27 2010, 02:47AM
Well first, what kind of transformer is it? Can I get a picture?
LIGHT
Sat Nov 27 2010, 04:09AM
LIGHT Banned on 4/6/2011 for unsafe, irresponsible behavior.
Registered Member #3442 Joined: Fri Nov 26 2010, 04:09AM
And I have a few relays but I cant figure what pins the + and - are, there are like 6?
LIGHT
Sat Nov 27 2010, 04:15AM
Sorry Grenadier.
I just have essentially made this. Link2
I just want to make it spark without me having to touch it on, maybe I can get a relay.
Adam Munich
Sat Nov 27 2010, 06:36AM
Use a 555 timer to switch a relay on and off, there's your automatic-ness.
Here, I designed this really quick, it should work. The pots control the timing and duration of the pulses.
1290839813 2893 FT101438 I
LIGHT
Sat Nov 27 2010, 07:52AM
To complicated, I'm new to most of this.
I will use a relay -.-"
or anything easyier.
LIGHT
Sat Nov 27 2010, 07:57AM
If I just put house AC 240v into the secondary coil, that would be 50 sparks a second then?
But this would be much more dangerous.
Sat Nov 27 2010, 10:16AM
If you want to use the relay, get a bulb and battery, and work out which pins operate the relay, which pins are connected when the relay is open, and which pins are connected when the relay is closed.
you then need to wire it up through the pins that are connected when the relay is open, to the pins that close the relay, so that the relay operates, but then turns itself off, then turns itself back on again.
Some relays have a diagram on them showing how they are wired, which will help you work it out.
LIGHT
Sat Nov 27 2010, 11:41AM
Is there an easiyer way, as I dont just want to go on evay and buy a small item.
Sat Nov 27 2010, 12:03PM
The easiest way will be by using a file as previously described.
If you have a small electric motor and something like a cork, cut the cork so that it is square, stick it onto the shaft of the motor, but don't stick the shaft all the way through. cover the sides and front of the cork with aluminium kitchen foil and hold one wire onto the front of the cork in contact with the aluminium foil and hold the other wire so that as the cork turns the corners hit the wire, making and breaking contact as the motor turns. this will turn the transformer on and off very quickly.
This is how the distributor on an old car works.
LIGHT
Sat Nov 27 2010, 12:14PM
Well OK then ,but is there any more powerful transformers I can get to have a nice spark?
