  • Guests: 47
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
DIY flocking - need to get to 45000volts
McLarenboy
Tue Nov 23 2010, 09:09PM Print
McLarenboy Registered Member #3437 Joined: Tue Nov 23 2010, 08:59PM
Hey Guys
I was informed to ask my question here. I've been looking for the answer for a couple of weeks now and it's turning out to be quite difficult.
I'm trying to make my own flocking unit, i'm using a negative ion generator for this with a peak value of 7000volts. The results are like the professionals.
For those of you not familiar with flocking, this is the technique: Link2
Now my flocking unit is fine for small pieces but in order to do large pieces like dashboards and doorcards i need to get to 45000volts. This will create a very large electrostatic field. In this way i can apply the flockfibres from a relatively large distance. With my current 7000volts i get the static field only when the + and - are about one inch from each other.
The answer to boost the voltage is either:
- flyback transformer of a CRT-monitor
- cockroft-walton multiplier
In any case i'm no good at electronics and electricity. And the fact that it is dangerous makes it impossible for me to have a go.
I've found this link which offers some possibilities but which one could i use; Link2
Can someone guide me in the right direction?
Pinky's Brain
Wed Nov 24 2010, 02:25AM
So the only current running comes from static charge transfer of the particles? I can't imagine that's even in mA range. Together with the fact you want DC a multiplier is your best bet.
To reduce the number stages you will want to feed it from a comparatively high voltage source, but a CRT flyback based circuit is complete overkill. A xenon trigger transformer should do fine.
The "Battery Powered High Voltage Source of DC Power" power supply on that page you linked is a good example of what you need. A simple oscillator driving a high ratio tiny transformer followed by a multiplier. If you can find a circuit which keeps the sustained current below ~100 uA and the stored energy below ~100 millijoule it will be no more dangerous than a van de Graaff generator (which would probably work for this too, but is not very compact).
Or if you want something even simpler, you can use mains for the oscillation :
Link2 (<- don't use this, I'm an idiot ... read below).
EDIT : ugh I should really be more careful what I say, with 8 stages that circuit would actually have a pretty nasty amount of energy ... and you can't really reduce the capacitors in the multiplier because the low frequency would make the droop too high.
Coronafix
Wed Nov 24 2010, 04:13AM
I think t CRT transformer is your best bet.
If you pull one out of an old tv, you can get the multiplier too.
You won't get 45000v but you could possibly get 30000v.
Cool technique by the way. Been meaning to make a slot car track with a friend and have tunnels and bridges and all. Now I know how to make the grass. :)
hboy007
Wed Nov 24 2010, 07:00PM
HR8870 or HR80341 will output 45kV if driven correctly wink (oh I forgot: this is WITHIN specs)
Pinky's Brain
Thu Nov 25 2010, 01:37AM
Pinky&#039;s Brain Registered Member #2901 Joined: Thu Jun 03 2010, 01:25PM
I still say that is complete overkill, he is not drawing an arc or putting significant power into anything.
A tiny capacity high voltage AC source (like from a trigger transformer) followed by a multiplier should serve him fine ... and if correctly designed mostly safe to the touch too.
McLarenboy
Thu Nov 25 2010, 05:53PM
so which one would you suggest of these:
And then add a cockroft-walton mutlipier you say?
radiotech
Thu Nov 25 2010, 07:31PM
Before anything will move in an electrostatic field you have to charge it first. We called it frocking, and was used to coat clutch
disks in some tape recorders.
McLarenboy
Thu Nov 25 2010, 07:50PM
Ii've already covered that part Radiotech. I've succesfully flocked small pieces with the same result as professional equipment. But inorder to do large pieces i need to boost the power...
Thu Nov 25 2010, 09:08PM
Oh, for flock's sake.
If you're inexperienced with electronics, just make a Van de Graaff generator and stick your workpiece (flockpiece?) on top.
Antonio
Thu Nov 25 2010, 09:51PM
I would try a Wimshurst machine. More current than a Van de Graaff and simpler to connect. What is the material that is "flocked" over the substrate? I can make a test.
