  • Guests: 40
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
X-Ray Spectrometer
radhoo
Tue Nov 30 2010, 09:04AM
I see. Well then, looking forward to see it ready.
Last time I checked Farnell probably I didn't consider the SMDs, and a 100GO is still expensive. But now I see there are the 50G (SMD) resistors for 1.22GBP quite a good alternative.
Tue Nov 30 2010, 10:56AM
radhoo wrote ...
It's easy to 'tack' two 50G in series with solder to make 100G if you want to, and to solder some wire tags onto the ends, so you won't have to use them as SMD parts. In any case, at 100G the board is probably more conductive than the resistor! smile
Thu Dec 02 2010, 11:27PM
Friedrich and Knipping's X-Ray Crystallography Apparatus 1912
On April 12th 1912, at Ludwig-Maximilians University, Munich, Friedrich and Knipping used this simple apparatus to reveal the pattern of dots produced by the passage of X-rays through a copper sulphate crystal, in order to test a theory of Max von Laue (1879-1960), Paul Knipping's tutor. Von Laue's mathematical explanation of the Laue-Friedrich-Knipping phenomenon earned him the Nobel Prize for physics in 1914.
1291331223 543 FT0 Laue Apparatus 1
Wooden uprights from a blackboard easel, a kitchen table, and roofing lead have all found their way into the construction. The system of pulleys for raising and lowering the lead shielding box reminds me of the guillotine.
1291331259 543 FT0 Laue Apparatus 2
Fri Dec 03 2010, 10:08AM
Very nice! I hope you're going for the same steampunk style in your own spectrometer. wink
Fri Dec 03 2010, 11:53AM
Steve McConner wrote ...
I think it's wonderful, Steve, smile and I've since realised that the round brass plate at the heart of the instrument is the stage from a polarising microscope.
I wonder what was used to power the magnificent tube? A large induction coil perhaps...
Sat Dec 18 2010, 01:19PM
1292677563 543 FT0 Xray Tube On Mounting Base Plate Assembly 014
This is the base plate layout for the two Svetlana BS-5 30kV tubes.
The metal box houses the floating heater supply - two Enersys Cyclon 2V 8AH sealed lead acid E-cells - and the EHT negative input.
George Schmermund
Thu Feb 03 2011, 08:47PM
George Schmermund Registered Member #3304 Joined: Mon Oct 11 2010, 04:18AM
Here's a site where someone is really into their ion chambers! Link2
Thu Feb 03 2011, 09:01PM
George Schmermund wrote ...
No disrespect to you or Charlie Wenzel, who is a decent fellow, but you'd never get one of those contraptions to hold to a calibration standard for five minutes. As my project thread is all about measurement, it really isn't the place to debate the offerings of other web sites, no matter how great their merits may well be:
Nah
Thu Feb 03 2011, 10:57PM
Amazing!
All of this must cost an arm and a leg, and you must be a master craftswoman.
Thu Feb 03 2011, 11:31PM
Nah wrote ...
....you must be a master craftswoman.
Now that you say this Nah, maybe your right. cheesey
