  • Guests: 17
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
switching noise/spikes on buck converter
Tue Nov 16 2010, 08:56PM Print
So, what is the best means for subduing switching spikes? Higher filter capacitance? Using a particular, low ESR capacitor, or adding input/output series inductance? Someone must have dealt with this issue.
Thanks.
2Spoons
Tue Nov 16 2010, 10:19PM
Are these spikes on the output? L-C pi filters are good.
Daedronus
Tue Nov 16 2010, 10:24PM
I think I said this before...but a common mode choke will do the trick :)
Or at least severely attenuate them.
GeordieBoy
Tue Nov 16 2010, 10:29PM
Switching spikes where? Within the converter? on the DC output? conducted back to the input?
In general for reducing switching spikes and ringing in power electronics systems...
In this order:
1. Use fast switching diodes, schottky or FRED
2. Minimise stray inductance in switching and clamping loops
3. Minimise leakage inductance in transformers
4. Minimise stray capacitance across chokes
5. Slow down switching transitions to minimise Ldi/dt spikes.
6. Add dissipative snubber if all else fails.
-Richie,
Wed Nov 17 2010, 12:04AM
If my induction heater (the load) switches at 100khz, does it matter if my converter switches at a slower (36khz) speed, or should it switch higher? Does it make a big difference?
The switching spikes I was referring to were seen on the output.
Daedronus
Wed Nov 17 2010, 09:46AM
A induction heater should not care at all about some switching noise.
Also, if you feed DC to the induction heater switcher, the switching frequency of the buck converter feeding the induction heater, will not matter, DC is DC :)
On a power supply output you have two different things, voltage ripple and switching noise.
The ripple is more or less how much the voltage goes up and down between two cycles. This can be improved by having more bulk capacitance and a bigger inductor on the output.
The noise, the little high frequency spikes will not go away with a bigger capacitor and/or inductor. However a common mode choke will make them cancel themselves out.
I'm working on a half bridge smps that right now works nicely in open loop mode and I will try to post wave traces before and after the output choke as well as a picture of the choke itself which is a simple ferrite toroid with 2 windings.
Thu Nov 18 2010, 04:13AM
With regards to the gate drive, is this subcircuit acceptable?
1290053604 190 FT100703 Buckdriver
Daedronus
Thu Nov 18 2010, 09:24AM
The zenners are not really needed, and they should be rated at about 16v for a 15v power supply.
They are needed when you use a gate drive transform, because the output of the transformer is not as well controlled as in the case of a driver IC.
I would also add pull down resistors (10Kohm should do) on the pwm input and on the gate so they are not left floating by accident.
Fri Nov 19 2010, 08:40PM
I'm going to add a snubber.
I read this link
which seemed to provide some good information. The output capacitance of one of the igbts that I have is 370pf, so I was going to use something close to 1000pf.
Would this surface mount be acceptable? Link2
My output voltage can be near 750v @ 50A. Using this with a f = 35khz I get a power dissipation for the resistor as 15R @ 20W. This would be a big resistor. Any suggestions for what to do here?
Daedronus
Fri Nov 19 2010, 09:44PM
750v at 50a? are you sure? that's 37.5KW
What is your input voltage?
Also, buck converters don't normally use snubbers. Snubberrs are normally used to control the voltage rise on flybacks and ringing on half or full bridge smps.
A verry good source of information for building smps is this book:
Switching Power Supply Design by Abraham Pressman.
It does cover buck converters and more, I strongly recommend it.
Also, try to post waveforms for the noise/spikes that you want to filter out.
