bypassing over current on pc supply?
ubuntupokemoninc
Fri Nov 12 2010, 10:05PM
Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299
When i draw ALOT of current off of my zvs driver the filter circuit i made give an annoying 120hz ripple, i have like 5 pc supplies, could i bypass the over current in them?
Registered Member #575
Yes, if you can find the feedback stage and modify it. You should be able to dig up a few threads about modifying ATX PSUs, specially their voltage. Current should be just as easy if you know how it works and what to look for.
I've also seen people paralleling ATX PSU, with the right modification you could probably also do that.
Regards, Christian
