  • Guests: 51
Moderator bullying?
Thu Nov 11 2010, 11:18AM Print
All, here is a reply I made in the thread about harleys, and since our Moderator Daniel has threatned to delete it, I thought if I post it here, and talk about it, he probably won't delete it, but only lock the thread, which is his right.
This is an act of compassion, to help Dan avoid doing something hasty and make an A** of himself wink
Cheers, Finn Hammer (doing what he has to do)
Post below:
EastVoltResearch wrote ...
Dr. H. wrote ...
I won't wait for Dr. Spark to repply
Dan - stop being an ass****
Okay folks. Lets stop the namecalling and please stay on topic.
Dan, with your remarks in this post, you crossed a line you shouldn't have. This is general chatting, and demanding strict adherence to topic is just plain poppycock.
Now you may claim topic to be just what you _later_ said it is, but anyone with a minimum of social skill, can see that you are out to tease Dr. Spark by rewording his avatar. Of course, it is your right to tease a member of the forum, here in general chatting. Still doing so, and knowing how he is going to take that, is what makes you what you are. (readers can fill in their own wording here:______).
So please keep on topic and keep the namecalling to yourself, otherwise you're post will be deleted and the thread locked.
I refuse to be threatened like that on what is equally as well _my_ forum, and I also strongly suggest that you stop any of your tendencies to perform moderator bullying.
Just because you have the ability to censor doesn't mean that you should do so!.
I have no objections to this thread being locked, as the piece of trash it was from the start, however, I may assure you that if you delete this entry, I am going to make my presence felt!
Cheers, Finn Hammer
Bjørn
Thu Nov 11 2010, 12:19PM
It is obvious that the thread title in question was no coincidence. I have a slight problem grasping how it is a big problem.
If it is considered a problem then name calling is not the solution. Confer with a moderator or administrator in a rational way instead, that way we avoid things spiralling out of control.
So enough of this.
