  • Guests: 24
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
the world's first HF-sstc on IGBT 25MHz
zilipoper
Wed Apr 10 2013, 12:55PM
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
The world's first high-frequency generator for IGBT
IRGP50b60 work on frequency of 25 MHz
Uolkg4
1365598421 4152 FT0 7ib8thhtvg0
Qhe
1365598421 4152 FT0 N1gz3 4blh4
1365598421 4152 FT0 O2hunnyouwk
1365598421 4152 FT0 Qeatwyyplhi
1365598421 4152 FT0 Wkulg85a3xo
Wed Apr 10 2013, 12:59PM
Looks cool.
Is that coil really resonant at 25MHz? It looks much too large to be a 25MHz coil especially with a very high electrode such as that. (electrodes are about 1pF per inch)
zilipoper
Wed Apr 10 2013, 01:04PM
lol Calculate the resonant frequency coils
Wed Apr 10 2013, 03:14PM
What are the dimensions and what is the wire size?
It appears you are exciting the coil with various frequencies, so the 25MHz number looks like you might be hitting a harmonic and not the fundamental.
Perhaps 14MHz is the fundamental as you seem to be getting the most arc at that frequency.
teravolt
Wed Apr 10 2013, 10:29PM
as usual you come up with some thing different zilipoper, does it use a parallel or series primary.
Goodchild
Thu Apr 11 2013, 01:09AM
Wow that's awesome! What topology did you use to get the switch going that fast with low losses? I would assume some form of ZVS/class E?
Have you found out what your losses are at 25Mhz? I'm curious to how well it's working at that frequency. I'm a silent follower of your work and as always you are doing something new and innovative.
P.S. love the triple stack orange variac, not sure why but it made me giggle! tongue
Sigurthr
Thu Apr 11 2013, 06:08AM
Great work! I'd love to see the schematic for this build as well as know some info about the input power involved.
I can only imagine the difficulty in keeping stray inductances and capacitances at bay in this frequency range - it is hard enough above 500kHz!
zilipoper
Thu Apr 11 2013, 08:13AM
hi
EasternVoltageResearch
parameters of the resonator at 25 MHz
wire diameter 0.5mm
secondary diameter 2.5cm
Winding height 2.2sm
efficiency is less than 40% at 25 MHz
efficiency at 14 MHz is about 60-70%
simple oscillator circuit
then no Class E
Thu Apr 11 2013, 01:47PM
Very nice. The coils just look larger in the photos - optical illusion!
Nice work! Love the flaming arc!!!!
