Registered Member #952
Bringing the old but interesting topic up. I have a question: could hall switches (nonlinear; just on and off) used instead of linear hall effect sensors? Or do the sensors absolutely have to be linear?
Okay then. I'll just have to use infrared phototransistors. Hall sensors would've been so cool. I'd want to get rid of the need for a dual power supply for the op-amps. Maybe a noobish question, but how could this be done?
Registered Member #96
You can get linear sensors from old broken 5 1/4" floppy drives. Other sources include old style Panasonic VCRs (three are used in the capstan motor) as well as some hard drives. There is a modern equivalent which is SMD, however its inferior in sensitivity and directionality to the 4 pin SIL equivalent.
It may also be possible to modify the read head on a hard drive (this consists of a very small nanowire) with a constant current as a magnetic sensor, though this is very finicky and hard to do.
Registered Member #1512
Tesladownunder wrote ...
Reaching wrote ...
.. does anyone know if its possible to levitate a copper or aluminium disc stable via eddy currents(induction)?
It is possible to levitate a dish shaped copper or Al disc vertically but the power is large and the dish may be close to melting. I've not been able to manage it but 50Hz is rather low to work well.
Actually, there are several types of levitators for aluminum (and, presumably, copper) objects. The book Propulsion Without Wheels by E.R. Laithwaite is an excellent source for these levitators. Unfortunately, the book is rare, expensive, and out-of-print. I had to get it through inter-library loan. The book is mainly about induction motors, but has a whole chapter just on magnetic levitation, with plenty of how-to diagrams and theory. It's a great resource.
Keep in mind, though, that any sort of induction levitator for copper, aluminum, or other diamagnetic materials will cause the materials to become hot if they are pushed deeper into the magnetic field than is necessary for them to levitate (i.e. an aluminum bowl which floats at 12 inches and stays cool will become very hot if pushed 6 inches into the magnetic field with a nonconducting object such as a wooden rod).
Hopefully that'll do it. The device pictured here is very similar to a description of a levitator found in Harry F. Meiners' Physics Demonstration Experiments (more info can be found at Rick Hoadley's excellent magnet site- see link below.
As he notes, a levitator like this is quite expensive and labor-intensive. However, they are quite fascinating to see in action. Here's a picture of one (with a funny comment about cooking pancakes).
Registered Member #1497
@ MagLev: Your links are incorrectly formatted (valid url, but you borked the bbcode)
As for the levitators, could a 'quick, dirty and cheap' version be made using MOT's perhaps with the top "I" sections ground off exposing the E section?
