Registered Member #14
I have determined the formula for current given voltage, duty cicle, diode voltage drop and coil resistence (frequency and inductance doesn't seem to play a role)
It is used to set the max duty cicle on the tl494
I(rms) = (V * Df - Vd)/(R*(1+Df))
Vd is the diode voltage drop Df is the duty factor (Ton/Toff or D/(1-D) where D is the duty cicle)
It is slightly less then expected using the simple V*D/R formula and it is due to the diode voltage drop
Setting Vd to zero produces the simple formula V*D/R that is good for a worst case estimation
Registered Member #10
Reaching wrote ...
.. does anyone know if its possible to levitate a copper or aluminium disc stable via eddy currents(induction)?
It is possible to levitate a dish shaped copper or Al disc vertically but the power is large and the dish may be close to melting. I've not been able to manage it but 50Hz is rather low to work well.
Registered Member #76
it works with 50hz and with a relative low current (around 5Amperes) heres a video of a levitating heatsink, ok not really i need something to hold it in place. the coil is directly connected to Mains, like a transformer
Registered Member #51
After some tweaking, it seems that to fix the stability problems, all I needed to do was lower the frequency a little. Perhaps to make it stable, the frequency has to be kept near the max frequency of the field effect sensor. Im not sure, but it is working very well now.
Registered Member #316
It would be neat to put the whole thing in a vacuum and set the magnet spinning, just to see how long it would go. you would probably have to connect the coil to an aluminum bar which would connect to the base of the chamber, to sink heat.
Reaching wrote ...
it works with 50hz and with a relative low current (around 5Amperes) heres a video of a levitating heatsink....
Thats a nice shot. With 550W input something will melt eventually though
My display maglev has spun for up to 90 minutes in air. Needs a very deft flick of the wrist though to keep it in the right spot but still rotating fast enough.
Neat stuff. I am starting to get inspired to make one for a display at the University on their Open Day in a few months. My museum one is just a bit too much to drag down for the day.
This time I want BIG. Perhaps levitating a really big spanner or perhaps a notebook computer or radio. Or for real cool a small magnetic levitator.
I just need to get my other 500 projects out of the way first....
I have made a levitator with this principle , except using one error amplifier as buffer for limiting the duty cycle, using a PNP bipolar driven dyrectly by the tl494, and using a diode to kill the offset of the amplifier, making the amplification easier with less offset voltage. I have only problems with the magnet overheating (max current 1.3A, "usual current" 900mA). Maybe i should use more turns. Anyway it is able to levitate a supermag structure weighting 80grams at 1 cm from the core.
