  • Guests: 15
Vaxian (17)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Robotic Path Planning In 2D, How Simple or Complicated Can It Get?
Dr. Slack
Mon Aug 12 2013, 05:30AM
Patrick wrote ...
... but am I creating a mesh in x and y like a grid, or as a polar system? the lidar is polar, but the navigation doesn't have to be one or the other.
That's the beauty of the system, the coordinates can be in any system you like. Navigation will always avoid crashing, though a path of true least cost requires that the model costs represent the true real world costs. So if you implemented a log-polar model with uniform resistors, you would find that the chosen path always avoided the origin. Angle cosines work well for robot arms.
Polar lidar results are probably too low level to be using directly in a higher level planning tool like this. I agree with Steve's layered approach. When you develop, you will want to work on very low level, or higher level seperately, and will need a well thought out API to be able to swap modules in and out. The natural coordinate system for the higher level map data will be cartesian, whatever the robot eyes see in.
Mon Aug 12 2013, 12:53PM
The robot arm and the 'copter are fundamentally different in one respect.
The robot arm is controlled by hydraulics/steppers and can 'freeze' while a decision is made.
The 'copter' can't 'freeze', it is 'dynamic' all the time.
As Steve has explained, any form of AI should have 'self preservation' as it's priority (subject to the 'Three Laws', of course). Mapping surroundings should be second order priority, and the 'Mission' should be third order priority, in my opinion.
Mon Aug 12 2013, 04:46PM
Steve, im still thinking on the memory problem.
as for the lidar, ill convert it to Cartesian, and the navigation grid too. Ill have immeadiate interrupts for self preservation if some minimum distance is violated.
im not sure how to code blocks of functions and then have them run as needed though, and yet still keep the PID flight controller up and given the highest priority. im looking through my book now. im not as good at this coding bit as you guys, im mostly a fabrication and electrical guy...
Mon Aug 12 2013, 07:08PM
Interrupts are your friends in this kind of situation. Typically you would set up a timer interrupt to run the flight controller tens of times per second as an interrupt service routine (ISR). Whenever the interrupt fires, the processor puts its current task to one side, executes the ISR, then resumes the original task where it left off.
Matters often come unstuck when trying to communicate between the ISR and the rest of the program. It is all too easy to bodge up some ad-hoc system of flags and variables that seems to work but actually has a hidden race condition. (I believe most of Windows 3.1 through to ME was written like this smile ) For all but the simplest communication tasks, you should use synchronisation objects like critical sections and semaphores, and then you have to watch out for deadlock.
My favourite method nowadays is a STL queue protected by critical sections. The critical sections protect the queue from race conditions (needed as the STL is not thread safe) and the queue protects the critical sections from deadlock (operations on a queue never block) so it "just works".
Mon Aug 12 2013, 07:41PM
Steve Conner wrote ...
This is exactly what I'd do. smile
Tue Aug 13 2013, 11:34PM
im looking up all my old homework on ISRs for the STM32/ arm cortex stuff now.
Thu Aug 15 2013, 02:53AM
im laying up carbon and glass composite right now. im putting together a more capable tri-copter, just for path planning demonstration. it will have a 2 kg lift capability and the ability to fly through human doorways and halls.
im not abandoning my bi-copter, but that tech isn't capable or mature enough yet.
BigBad
Fri Nov 29 2013, 05:11PM
For shortest path calculation, the Dijkstra algorithm runs quickly and is simple and can deal with loops.
Shrad
Fri Nov 29 2013, 05:42PM
there are game path finding algorithms available in python or other simple languages which would be able to run on such systems as STM32
