  • Guests: 18
Finn Hammer (72)
Blue Adept (43)
Nickel (68)
05/18 AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
Odin The All-Fragger: a large DRSSTC
teravolt
Wed Jul 09 2014, 04:51PM
other than the hard switching do you think that you might have any shoot through and would any dead time be good for your set up?
Wed Jul 09 2014, 05:51PM
The PLL driver has adjustable dead time, I was using 500ns for the 12T4. I didn't see any signs of shoot-through on the Rogowski coil signal. I tried deliberately reducing the dead time, and some very obvious nasty spikes appeared, which shows that the Rogowski coil is capable of detecting shoot-through and that some dead time is needed.
I just ran the 12T4 up to 1500A at 600V bus voltage, while twiddling the fine tune knob back and forth to provoke a little hard switching, with no apparent ill effects. Now to repeat the experiment with the 128.
Uspring
Wed Jul 09 2014, 06:31PM
The funny thing is that even with this large hard switched current, and turning off the IGBT as fast as possible with no gate resistors, and probing as close to the die as possible, the voltage waveform is very clean. I can't see any spikes that would endanger the breakdown voltage of the device. If I tune the phase lead for perfect ZCS according to the Rogowski coil signal, the spikes get somewhat worse, and if I tune it for leading current, the spikes get terrible.
Isn't this as expected, i.e. no spikes with phase lead and increasing tendency as it gets low or turns into phase lag?
Wed Jul 09 2014, 07:11PM
I think with phase lag, the current has already commutated to the diode in the bridge leg that is about to turn off. When the other leg turns on, it causes forced recovery of the diode and this generates a large and ugly spike. However the switches are guaranteed zero current turn-off.
With phase lead, the switch that is turning off hands the current over to the diode in the leg that is about to turn on. The switch doesn't get zero current turn-off, but it gets zero voltage and current turn-on and the diode gets soft recovery.
When I think about it, I guess phase lead gives the cleanest waveform because the IGBT turn-off is the slowest part of the whole process, slower than the turn-on or the diode recovery, so it generates less high frequency energy. This doesn't imply that clean waveforms equal efficient operation though, if anything the opposite.
Wed Jul 09 2014, 07:54PM
Steve Conner wrote ...
Can this spike not be controlled with a simple snubber capacitor across this diode, or would this lead to other problems?
Wed Jul 09 2014, 08:36PM
Yes, the capacitor would just add to the diode's reverse recovery charge and make things worse.
Snubber capacitors can be used on an IGBT or MOSFET bridge, but not with phase lag. You need phase lead and deadtime. Instead of handing over to the diode, the device that is turning off hands the current over to the capacitor. The switching losses are reduced as the capacitor slows the rate of rise of voltage.
The arrangement is called quasi-resonant or sometimes Class-DE.
Uspring
Thu Jul 10 2014, 09:27AM
Yes, exactly. In the case of phase lead, the tank current takes over the recharging of parasitic capacitances, while in the case of lag, the turning on transistor will have to do it. The fast turn on times in the latter case leads to spikes, while for phase lead the transistor current during turn off might be reduced by the parasitics.
Thu Jul 10 2014, 11:06AM
Ok. I certainly don't intend to go too far OT here, but would faster diodes be sufficient here?
Thu Jul 10 2014, 11:13AM
The diodes are built into the IGBT bricks, there is no option to change them. tongue They are already as fast and soft recovery as diode technology allows (at the time the old surplus IGBT brick was made)
teravolt
Thu Jul 10 2014, 01:36PM
to bad a big series diode in the couldn't be added to each IGBT drain to block the reversal. do you think that it would help with hard switching
