Registered Member #96
Hi all.
Thanks to some research on the very fringes of science, it is now possible to start building a device that is capable of generating a somewhat stable interdimensional gateway for radio waves.
The basic design uses a modified version of the "Tajmar Effect" although Evgene had some input on this back in 1995. Rotating a toroidal superconductor while in a <0.2T counter rotating magnetic field from external conventional copper coils at radio frequencies seems to be the key here. As it turns out it doesen't need to be that pure, any old material will work as long as it superconducts at liquid nitrogen temperature (77K) and is stable to a reasonably high Jc.
The innovative step here is to use an accelerometer AND radioisotope to sense the antigravitomagnetic effects as due to relativity an antigravitomagnetic field will indeed shorten half life. The isotope used can be any reasonably active one such as 226Ra or 241Am and any old tube can be used as the field energy can be quite large and saturate a more sensitive one.
Thanks to this fortuitious discovery it is possible to use feedback effects to cause a power inversion in the system so it only needs to be jump started for the field to "take off" so to speak. Once generated to shut it down just slow down the rotating superconductor and it should dissipate.
This could have all sorts of applications; sending radio signals long distances across the visible Universe comes to mind without that inconvenient inverse square law and the large transmitter thus needed.
Current status: midway through making the HTSC disk, just need to do some fine tuning to optimize Jc and this time use a bracing disk on both sides to stop it fracturing as NASA discovered during their experiments. Oxygen annealing will be tricky but doable with some funding, MW calcination is also doable and my MW oven is working fine now it has additional cooling.
Possible method of forming an artificial wormhole for radio waves only. Theoretically possible, with 10+ GHz the power requirements would be quite low (ie tens of megawatts) and if a MASER was used then even lower.
