Registered Member #3147
I decided to build a regulated PSU of the whole thing, including box! My dad helped me some with the making of that aluminium box.
Here are the pics:
Note the thermostat that you can see bolted onto middle cooling-element, it turns the fan on at +70C and off at +40C. It's usually cold enough under 15A that no fan is needed.
Things to work on is: - Get bigger smoothing cap! 47000uF 80V isn't enough, voltage REALLY sags while drawing 30A @ 30V.
Current control isn't so accurate but atleast LM723 regulator can keep those 2n3055 transistors from frying! The schematic for my PSU is taken from this site: (not my drawings! I stacked more of power transistors)
Registered Member #1334
Steve McConner wrote ...
You can always spot a German on electronics forums because they don't write "uF", they use the actual mu symbol. The reason is simply that German keyboards have mu on a key, but everyone else has to remember Alt+016-whatever, so they just type u instead.
I've always liked the way that sensible s/w packages, like LTspice, convert "u" to "µ" in the right places, i.e. for component values.
FWIW, when doing my internship at ITT (actually STL Harlow) I remember using "puff" for pF but always "micro" and "milli" for u & m. "muff" was something completely different...
Registered Member #543
Good work, Freitsu!
Freitsu wrote ...
It may not suit all users, in all circumstances, and applications, but it is often convenient to use industrial or automotive lead-acid accumulators to meet occasional or intermittent heavy current demands. When not in use, the batteries can be kept float charged, so they are always ready for use.
I also find lead acid cells, such as the Enersys Cyclon* I've pictured below, very convenient as floating X-ray heater supplies in grounded anode configurations, and which you might find useful in your own X-ray work:
Registered Member #3353
Hi Freitsu, nice work with the power supply!
I will show you two 24V transormers i have, maybe you can compare the size to find out about the VA rating of yours. The smaller is 700VA and the bigger 1600VA (input is 220V, i assume you have the same in Finland).The small uses 2.5mm wire and the big somewhere about 4.5mm.
As for the voltage sag, it seems kind of normal to me. 30V x 30A = 900VA which is not a small amount of power. I am pretty sure that it is normal to have a little voltage drop when you get near the max current capability of the transformer. I know for sure that when a 24V transformer (AC circuit) is under heavy load (more than its normal rating), voltage can go down to even 17V.
For example, if you connect a 0.1Ohm resistor to your transformers output, it will "try" to draw 240Amps! Since your transformer is not rated at 6KW, he cannot supply that current and the voltage with sag (big time, since this is practically a shortcircuit for the transformer).
I could be wrong, but be sure of your theory before spending money on bigger caps.
-- WARNING - "REDNECK's", UNSAFE WAY TO GET AN ESTIMATE OF A TRANSFORMERS VA RATING -- It just occurred to me, you can use that as a (crude, unsafe, vicious) way to get a rough estimate of your transformer rating: If you have a multimeter, monitor the primary current draw (eg connect it is series with one of 220V input cables) and for only a second shortcircuit the secondary. Then you can meause the exact main voltage and multiply the two numbers to get the VA rating (4,5A at 220V = ~1000VA). Actually you will get a bigger number, as all transformers can be over-loaded to some extent, and ONLY for a very very short period. I know, i know it is cruel, and i assume you have the skills to do that without blowing up you multimeter or killing yourself (mains 220V are involved). -- USE AT YOUR OWN RISK as a last resort method only --
