  • Guests: 14
AlexRU73 (39)
05/18 AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
176 photoflash capacitors parallelled
Freitsu
Thu Nov 18 2010, 02:07PM Print
Freitsu Registered Member #3147 Joined: Sun Aug 29 2010, 10:53AM
Hello there everyone!
I went to a photoshop in this town I live and asked for used disposable cameras, and to my surprise they had over 200 of them that they could give me. :D
Getting the capacitors out of all 200+ cameras was a project in itself aswell!
Here are some pictures showing the finished capacitor bank and all the cameras. ;)
In the pictures you can also see my crude version of a coilgun. I used 50RIA120 thyristor for triggering on that experiment...
1290088921 3147 FT0 Pict0004
1290088921 3147 FT0 Pict0005
1290088921 3147 FT0 Sl380011
1290088921 3147 FT0 Sl380012
Thu Nov 18 2010, 02:16PM
My goodness, Freitsu, you should be given a prize for enthusiasm! smile
Freitsu
Thu Nov 18 2010, 03:11PM
I got many months of frustration out when tearing those cameras apart! :)
Killa-X
Thu Nov 18 2010, 03:38PM
Nice. Most I did was 100 xD good luck with it!
Thu Nov 18 2010, 08:01PM
And they will work better than a typical computer grade electrolytic of the same value because they are made for pulse applications. And, because there are tons of small low ESR caps paralleled, that will further reduce ESR and ESL.
Oh, and if you need an SCR, the SK065K is a nice SCR. I have paralleled 5 and they work fine for 600j... And if you want faster current rise, series two parallel banks, i bet that would toss an alu platter hard enough to make it fold around a steel bar smile
Freitsu
Fri Nov 19 2010, 05:26AM
Thanks for the suggestion about connecting those 2 banks in series, Arcstarter. But right now there comes enough power out of it to shoot a 8 mm diameter X 40 mm steel rod pretty damn hard, I have no idea about the velocity but if you blink, you'll miss it! ;)
RLC simulation says I have about 1200 amps going through that scr, thats right on the edge what it can take so right now I'm waiting to get some more heavy SCR's from Timo here on the forum.
Fri Nov 19 2010, 09:54PM
Lol if one of them fails and stuffs up the whole bank.
Sat Nov 20 2010, 12:53AM
Freitsu wrote ...
I used one to trigger some lower ESR caps, which equaled 200j and it never died :P
Freitsu
Sat Nov 20 2010, 09:12AM
GhostNull wrote ...
Actually 2 of them initially failed while testing those banks separately, they're really going out with a big BANG. Earplugs is a must but ofcourse I didn't know that so my ears were beeping for some time after that experience...
Arcstarter wrote ...
It died yesterday, RIP. Time to get some more durable now.
Sat Nov 20 2010, 10:55AM
lol xD all those months wasted D=
Disposable camera photoflash capacitors don't tend to be very reliable considering they only need to work for 27 cycles (number for exposures on a standard film thingy) and costs are kept at a minimum since they are disposable/single use
