  • Guests: 22
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Marx Generator Kits - FREE Kits for Evaluation!
Mon Jan 07 2013, 06:42PM
Just an obvious warning .....
assuming that the multiplier is fed from ac line;
USA 110/120 Vac is half of UK (240Vac), Europe (220Vac) etc.
so the multiplier capacitors and diodes should be >= 800 V pk rated
and the Marx Generator dc input will be twice expected
unless the number of multiplier stages is reduced/halved.
You could either make two pcb versions using higher voltage rated devices
OR re-do the pcb to allow
2x(>=400V) diodes in series and 2x (>=350V) capacitors in series as an option.
Less critical is the line frequency, giving better output on 60 Hz then 50 Hz
I like the spark gap holes.
A good area for experimentation is the spark gaps;
material/pointiness/optical alignment etc.
maybe a project for receivers of the sample kit ?
Unfortunately my 'scope probe only goes to 40kV
and I haven't a present need for a Marx generator or I'd volunteer.
Also, a small warning ...
warn users of potential x-ray and/or u.v. hazard as well as noise/fire/electric shock/etc.
ALSO: you should consider some on-pcb resistance at the multiplier output
as well as the Mark generator input
because I made a 15-stage (30x 1N4007 & 10n 1kV cer.) multiplier from an ionizer kit
and blew it up by bypassing the on-board series output resistors !
Mon Jan 07 2013, 07:23PM
I would be interested in testing one of the kits. I have experience assembling such kits and the proper knowledge of electrical safety.
I have the test equipment to measure the output voltage of the CW and the current output of the marx too. Sounds like something fun to try.
Ben Solon
Mon Jan 07 2013, 10:13PM
Very cool! they might work well for dielectric analysis as well on a small scale. I like how they're mounted right on the pcb, I hope they don't start breaking down. If any are still available, I live in Massachusetts and would definitely like to beta test one.
Meatball
Tue Jan 08 2013, 12:50AM
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
I've got the time and tools to put something together and evaluate it. I'm in NE, let me know if there are any more samples to test.
Tue Jan 08 2013, 02:44AM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Looks nice. Maybe someone could post a video of it in operation. I bet its noisy.
Polonium210
Tue Jan 08 2013, 05:36AM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
EasternVoltageResearch wrote ...
We can ship internationally if you do pay the shipping which will be about $20.00.
I as well am interested. PM sent.
HB
Wed Jan 09 2013, 10:54AM
HB Registered Member #4146 Joined: Tue Oct 18 2011, 02:01AM
I'm in WI and I would be interested in testing one of these kits if any are still available. Very professional looking boards. Great work!
Myke
Wed Jan 09 2013, 11:17AM
If there are any more still available, I'd be interested in testing one out.
-Khalil Elbaggari
Wed Jan 09 2013, 01:51PM
Thank you everyone for the interest in these kits. I will be contacting you via PM to get your addresses so i can ship out the kits to you. Thanks again!
rp181
Wed Jan 09 2013, 07:52PM
If you still need more people, I would love to try one out.
