Improved single transistor flyback driver
quicksilver
Registered Member #1408
Doesn't require 4.7K capacitance but it needs to be fairly close & (in terms of voltage) a good idea is using one approx 1/3 larger than input voltage. RE: heat sinking & related issues, consider the current level of the battery as well (use heavy traces or wiring). The circuit itself is very flexible and works well for what it is. I really like the 2N3773 and if you have a decent heat sink the MJE13007 (I've also used 13009 savaged & all was fine) have gotten great results.
SaberShip
Registered Member #4546
This is a great circuit! I'm using a MJ15003G transistor and have played around with it alot. I can get some nice 4cm arcs starting at about 1.5cm and the transistor hardly gets warm after several minuets on my 5" heatsink!!
I was wondering if the resonance cap across the transistor could be applied some how to this circuit using the MJ15003Gs ?? http://www.kronjaeger.com/hv/hv/src/fly/flyback1.png
The website that this schematic comes from is right here: http://www.kronjaeger.com/hv/hv/src/fly/index.html
Any insight would be appreciated, thanks!
