  • Guests: 30
Skynet (32)
syntroniks (15)
Powerfulman (27)
05/23 lokeycmos (42)
05/24 Simon Barsinister (62)
05/27 Daniel Davis (53)
Light LED with 4 nanoamps
Newton Brawn
Thu Apr 30 2015, 04:02AM
Paul,,
very good.
If you spend 60 seconds to charged the a 3.3nF cap, you will spend 20seconds to charge charge a 1nF cap.
Now you have to work in the circuit that will discharge the cap into LED.
I may sugest you follow the Antonio experiments.
The schematic was posted Wed Apr 22 2015, 12:39AM
the spark gap will not drain all voltage from battery
Zamboni
Fri May 01 2015, 01:16AM
Zamboni Registered Member #2836 Joined: Fri Apr 30 2010, 01:24PM
Newton Brawn wrote ...
Paul,,
very good.
If you think it will work, I was going to try a 10PF cap, and a 100PF cap. Do those values sound good? If not, what would you suggest?
What resistor value would be a good start?
Antonio's design, though very inventive, will not work with my Device. There is no way to place a wire on the needle of the swinger. Any friction (from the wire) will stop the device.
Paul
Newton Brawn
Fri May 01 2015, 02:16AM
Paul,
All you need is in the schema posted by Tony on
Wed Apr 22 2015, 12:39AM.
" 430 uH requires 53 turns of #32AWG wire wound on a section of PVC tube with 8.8 cm of diameter."
This schematic is the summary of all work done by Antonio.
Later, after you have adjusted the gap, insert a 100Meghom between the battery and C1
4 diodes 1n4007 in series will be fine
Fri May 01 2015, 10:14AM
Won't the buck converter design place extra strain on the pile, as far as current draw in concerned?
By boosting the voltage, it leaves a voltage deficit behind, which places an even greater current draw on the pile?
Newton Brawn
Fri May 01 2015, 10:06PM
Ash,
Yes, you are right.
It will place some strain in the pile, BUT just the time for Paul to adjust the spark gap. THEM he will place a 100 megohm between the battery and C1.
The gap will disrupt the voltage before the complete battery drain.
The converter is supposed to buck the voltage.
Zamboni
Sun May 03 2015, 07:02PM
Paul,
I will order a 100 Mohm resistor and give it a try.
Paul
Sun May 03 2015, 07:26PM
As you're aware, there are different quality resistors on the market.
Not sure what the best type would be here. Maybe a film type?
Zamboni
Sun May 03 2015, 11:16PM
Ash Small wrote ...
I was going to get this one. Do you think it would be OK?
Mon May 04 2015, 10:10AM
I imagine it will be ok for testing purposes. Apparently some lose accuracy over time. Maybe a 'name brand' with a datasheet, etc. would be better for 'production models'. Others here probably know more than me about this.
Zamboni
Sat May 09 2015, 12:41AM
Ash Small wrote ...
I saw this from Mouser. Does it look OK to you? Even has a data sheet. If it's good, I will order tomorrow.
588-MOX-750231006JE
