Registered Member #2431
Tesla coils are wound nice and neat from there low voltage end to their HV top load. Ive built a winding machine.
Instead of using the traditional "pie winding" method on plastic bobbin, is it possible to wind continuously from top to bottom and keep one end grounded such that the insulating ability would be similar to a Tesla tube and "pie winding" but without the annoying grooves , yet still having the same insulating value ?
I also plan to vacuum fill with epoxy, the whole thing at 400 Microns. The insulation will be layers of epoxy-kapton-Electrical Paper of several layers on all side between the bobbin and the primary/ferrite.
It will have a calculated insulation value of 80kv in all directions, a de-rated value of 50kv and a real running voltage of 30kv.
Registered Member #61569
We have build a ferrite transformer very similar to the method you have mentioned. It does not have the same insulation performance like a tesla coil, since the ferrite core is grounded. But in terms of the insulating voltage between the individual winds it is the best method. Here is the link to the youtube:
Registered Member #1321
Wow nice work. I want that ferrite core; no doubt Patrick wants it too.
What kind of peak output voltage are you getting and at what frequency?
Also do I assume correctly that the nylon wire tie on the lathe chuck is part of some kind of an optical turns counting system? If so what does the rest of the turns counting system consist of?
Thank you very much! Unfortunatly we only get to 70 kV of peak output voltage at 7 kHz. If we increase the frequency the output voltage will decrease. And by lowering the frequency the core gets into saturation. Our aim is 100 kV output voltage in order to feed out voltage multiplier.
Correctly, the cable tie is for counting, not optical but "mechanical". It hits the mouse and it adds +1 in the microsoft calculator
Flachzange wrote ...
Stunningly clever !
Was that box vacuum oil drawn ? Im going to do both a transformer out of oil and one out of epoxy and compare the insulating results. I worry about heat and pressure changes causing leaks out of a liquid system.
Registered Member #2099
Nice work! The handy turns counter prompted me to upload an old video with mechanical turns counting. It's about a sense coil made for a 3 inch (76 mm) solid electromagnet pole. I hope the link works. First youtube for me in many years.
Registered Member #2939
It can be better. With multilayer insulation you are unlikely to get defects aligned between layers, whereas a defect in a single layer can compromise your insulation quite badly.
It seems epoxy sticks to kapton. I want to use electrical paper, oil and kapton film. ill vacuum dry and draw the oil into its container, but i worry about temperature causing pressure changes. i want to use milled plastic pipe and thick plastic sheet, but worry about needing a relief valve or something for temperature or altitude change ...
proud mary suggested a bourdon tube from a barometer but i dont know how much expansion is needed. Also i was thinking of a gas ballonet like in a helium zeppelin or balloon.
The gas ballonet surrounded by oil would be easily compressed. since gas is easily compressed the oil would stay at a constant pressure while the ballonet shrinks or expands. It would be a passive system and the envelope size could be chosen for the needed oil volume.
Rubber bladder to accommodate thermal expansion of oil is common. How about rubber bulb from an eyedropper, or for honking a horn, or part of a rubber glove?
Need to mind the material compatibility of oil and elastomer. It's not too soon to start soaking some samples to see what happens.
