  • Guests: 23
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Plasma Vortex
Wilson
Sat Mar 11 2006, 12:15PM Print
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
I was playing with HV from a FBT yesterday and noticed a strange effect- By holding an electrode over the centre of a ferrite ring magnet from a microwave, the plasma forms a vortex. Reversing the connections results in a reversal in the spin direction.
Any comments on why this occurs?
I have an unsubstantiated theory that there is a force acting on the plasma arc , similar to how a force acts on a conductor in a magnetic field, such as in a motor, producing a spinning effect.
Either that or the plasma with all its loose electrons is responding in some unique fashion to the magnetic field.
Either way its a rather cool party trick cheesey
Enjoy the Video
(Ignore the unsafe tofu container, lol)
Sat Mar 11 2006, 06:27PM
wow!
That sort of reminds me of my quasi water diode experiments. The plasma was less dense than normal where it touched the water, so I guess that made it more unstable and thus it could give erratic behavior?
Madgyver
Sat Mar 11 2006, 07:14PM
Actually its a simliar effect like in a cylcotron.
Check out this page (german):
Sat Mar 11 2006, 07:54PM
Nice One !!!
That was fascinating, well done.
I've been 'playing' with high voltages on and off for 30 years
and never seen that before, never even thought about it.
You'd better Copyright it - could be the next Plasma Globe/lava lamp etc.
P.S.
The current in the arc will experience a force at right angles with both the current and the magnetic field, (Fleming’s Left Hand Rule etc.)
Each ion in the arc is electrostacically attracted to the electrode/magnet
and gets 'pushed' sideways continuously by the magnetic field
this continuous sideways acceleration produces a spiral in the direction of the electrode
- your vortex.
You have effectively re-invented Faraday's motor
using plasma instead of wire.
Sounds like there's a fortune to be made on eBay under 'New Age' cheesey
Sat Mar 11 2006, 08:25PM
I wonder how would behave an arc between two ferrite rings, covered with alu foil and connected to the HV terminals. It would rotate?
Tipp
Sun Mar 12 2006, 01:59AM
Tipp Registered Member #215 Joined: Sun Feb 19 2006, 09:14PM
Thats extremely cool, nice job. shades
Magnets + HV = some very intresting effects
Omicron
Sun Mar 12 2006, 04:20AM
Could it be the magnet is pushing out some of the ions and pulling some in? That would make a twister effect. I have used strong magnets to move Alpha and Beta particles.
Wilson
Sun Mar 12 2006, 06:55AM
I made another video. This time with 2 magnets separated with 2 ceramic spacers, and no water.
Here's the link
It is interesting to note that the top magnet is not connected to GND like the bottom one.
The 2nd vortex while forms is also rather unstable
Enjoy smile
the_anomaly
Sun Mar 12 2006, 04:03PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Well I had to do some playing and found some cool effects. If you increase the voltage the arc seems to spin faster. I’m using a flyback (dc) powered by the ZVS flyback driver powered from a variac. increasing voltage
The highest I tried was about 40 volts because my variac was nearing its current capacity(5amps).
And also when arcing to strong Nd magnets the arc seems to widen where it touches the magnet.touching magnet
The camera does not do justice. This is really cool if you try it yourself.
cjk2
Sun Mar 12 2006, 07:36PM
Well after seeing others results I wanted to try this myself. I used a 1" "Super magnet" in the experiment below. I also tried with a magnetron magnet but it was not as impressive. Its cool how the entire surface of the magnet seems to glow rather than one small point like you would expect. and arc also seems to like dancing in a circular pattern instead of staying in one place. I powered the setup with my "super ZVS" using just 30v in of filtered DC. I would have gone with a higher input voltage, but the core was spraying corona to the secondary because the power supply was just a variac and not isolated from the mains...
Video
and a picture:
1142192093 51 FT3785 Cjkvortex2
Edit: Trying it inside the microwave magnet is really cool! The plasma spins so fast you just see a bright disk of gas.
