  • Guests: 62
Daniel Davis (53)
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
ZVS Flyback Driver Nice sparks!
David
Mon Mar 12 2007, 10:46AM Print
David Registered Member #552 Joined: Mon Feb 26 2007, 08:42AM
First of all, nice to meet here, I have been trying to register for moths, but it was disabled and the mails wont do anything. My name is David, I'm from spain and 20 years old, this year will be 21 hehe.
I made an electronics studies, but when i made some sparks I got engahed by de HV. I burned lot of transistors, especially those 2n3055s wich are the worst i´ve seen for flyback. Two weeks ago I decided to make this circuit, I was really impresed about its power.
Im using the improved version of the zvs circuit from Vladimiro Mazilli. Dunno the power, I think it will be over 350 W. now the driver is dead, as it sometimes it doesn't oscillate, and I was using a rewinded MOT so lot of current passed trought the IGBTs and they exploded (no oscillation = total shortcircuit). Using 40V that dropped to 34V with the 15cm arc. It ignites at 5 cm, but the current is so high that the arc can be distanced up to 15 cm. Flyback needs to be inmersed in oil, otherwise it arcs with everything it finds: table, primary, even the hv cable isn't enought to insolate so high voltage, I have to use a 20 cm plastic thing to keep sure that it wont hit me hehe.
1173696356 552 FT0 Dsc01036
1173696356 552 FT0 Dsc01037
1173696356 552 FT0 Dsc01038
1173696356 552 FT0 Dsc01039
15 cm arc! panic! haha.
1173696356 552 FT0 Dsc01052
1173696356 552 FT0 Dsc01055
1173696632 552 FT21961 Dsc01033
41 secs arc video, just 7cm.It was the first time i tried the rewinded mot and the circuit wasn't well optimized. Without spacers and a few turns more on the MOT it got lots of more power.
That big 50hz noise wasn't the arc itself, was the MOT wich secondary was bad assembled and it was vibrating making a lot of noise. All that has been solved, so nexts videos I hope will be better sounded.
Frequency was over 25 KHz, great for my ears, I was fed up with the 2n3055s oscillator always running over 16KHz, disturbing everyone near it.
Now just the cat seems to be angry when i connect it haha
Sorry for the bad quality, I just have my mobile phone for making videos and photos...
]1173698123_552_FT21961_mov01034.avi[/ file]
Myke
Mon Mar 12 2007, 01:23PM
Nice cheesey . Could we please see a pic of the driver and the setup?
ShawnLG
Mon Mar 12 2007, 04:07PM
Awesome. Where are you hiding that MOT?
Mon Mar 12 2007, 05:45PM
That's really nice. You must have a tough flyback here because in my experience the internal diodes in the flyback usually toast in seconds with that kind of power.
Electroholic
Mon Mar 12 2007, 08:07PM
i see a ferrite transformer in the bowl of Si oil.
solid state MOT?
Mon Mar 12 2007, 08:42PM
Those are pretty powerful arcs, what kind of transformer are you using? I've got a short-circuit protected MOT power supply, 50V, so I'll have to do some more ZVS experiments soon.
David
Tue Mar 13 2007, 05:20PM
Haha none MOT here for making sparks. mistrust
Dunno why the flyback survives... When i tried the first time the power wasn't so high so it was strange that it arced itself to the ferrite or the primary, but when i tried with the MOT, thanks God I was using that plastic thing to move the HV cable, few seconds of a big capacitive corona discharge between the the plastic base and the metal table, and the plastic heated up, arcing to the metal table.I was at a friend's house, my table its wood, but still burned every where by accidental arcs. The plastic was 0,5cm width, seems to be PVC
I was really impresed too, used to make 3-4cm low power arcs, when i gave power to that... suprised suprised
When there's no arc, lost of corona is discharged in air, like a small sstc.
Here's my setup configuration:
- MOT rewinded to give 40V, with 4mm (i think, maybe 3mm)cooper wire for providing almost 50A without overheating
- "Brick" diodes; 120A 600V 80nS ultrafast rectifiers, can power almost anything ;P
- Filtered with three capacitors with a total of 11,300µF at 50V
This is the circuit
Flyback DriverAndrineriimproved
Some setup pics...
I mounted the circuit quickly and bad,just for make it look like it is normally, as I had dismounted it, to mount it again when i receive new IGBTs...
Rewinded MOT..
1173805410 552 FT21961 Dsc01109
brick diodes
1173805410 552 FT21961 Dsc01111
other angle, brick diodes again
1173805410 552 FT21961 Dsc01113
caps..
1173805410 552 FT21961 Dsc01115
driver, with screwed igbts still mounted xD
1173805410 552 FT21961 Dsc01116
another angle of the driver
1173805410 552 FT21961 Dsc01117
flyback, everything screwed up ;P capacitors disconected by one side, the orange wire is the anode of the flyback, i take it to make arcs far of the primary for insurance hahaha
1173805410 552 FT21961 Dsc01118
another pic of the flyback
1173805410 552 FT21961 Dsc01119
and the lastone..
1173805410 552 FT21961 Dsc01122
Also had tried to put a secondary self-made with less turns to give over 1-2KV, arc jumps at little distance but it can be distanced more than 1 cm, burning the electrodes quickly, even 4mm diameter steel electrodes burned up, maybe i can use this to make some welding thing hehe. No pics yet, i'll make someones when i get new igbts. Great arc-spark-emitting effect, dunno how to explain it in a good way in english hehe :P
Wed Mar 14 2007, 04:01PM
I have one question: since the driver produces a symmetrical waveform, how it comes to that the flyback doesn't instantly explode when drawing an arc? I'm asking because there is a HV rectifier in the flyback, so shouldn't it put dc "bias" on the secondary and instantly saturate the core?
Wed Mar 14 2007, 04:37PM
A fair question indeed. There may be a few things keeping these types of circuits working OK. Firstly, the tank circuit is resonant with a pretty good Q, meaning that energy is left over cycle after cycle. When the output is forward biasing the diodes, the Q goes down (since energy is being extracted by the arc) but on the reverse cycle, energy is only being added. But, why should it saturate provided the V*s product for the core isnt exceeded? But you are right in thinking that this circuit would be much better suited with an AC flyback, or at least something with full-wave rectification.
sparky
Thu Mar 15 2007, 06:42AM
Steve, have you tried linking 2 flybacks in a series arrangement using this high wattage driver?? ....might be a bit overkill - but 100 kV sounds FUN, especially at 300 watts or so!!
