  • Guests: 14
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Small SGTC.
Duncan
Thu Feb 15 2007, 03:51AM Print
Duncan Registered Member #524 Joined: Thu Feb 15 2007, 03:28AM
A few months ago I started making some rough plans for a new small spark gap coil, as I felt I had been deprived long enough tongue What I wanted to achieve was a small, lightweight and reliable coil that I can pull out every now and again for a run. I wanted it to be as hassle-free to set up as possible, and should need very low maintenance. I also wanted it to look nice and neat (so other family members wouldn't make me keep it out in the shed). My starting point was a 7.5kV 25mA NST I bought off the net, and a couple of wooden chopping boards from the local supermarket smile
I've been saving these little updates for a while, so here they are:
Cut the handles off two wooden chopping boards and rounded the edges to make it look like the handles were never there (which took ages). I cut some pine doweling into 125mm lengths and drilled some countersunk holes in the boards and screwed everything together with heavy duty galvanised screws, and it is as solid as a rock. It turned out to be heavier than I thought it would be, but that's no problem.
Here's a couple of pics (they're a bit dodgy, but you get the idea). Theres a bit of lens distortion which makes the back left doweling support look crooked, but it really isn't.
1171523911 524 FT1630 Frame
1171523911 524 FT1630 Frame2
Duncan.
Duncan
Thu Feb 15 2007, 03:55AM
The perspex arrived and I've drilled a 60mm hole in it and another one on top of the frame (so thay they'll line up when the perspex is placed on top of the frame.) The hole is for the secondary coil to go through so it will be able to sit nice and solid in the frame, and can also be removed easily if need be. I've also cut the PVC for the secondary coil, and spent about 2 hours winding the 0.2mm copper wire. There are approximately 1040 turns in total. Here are a few pics:
1171523911 524 FT1630 Cut1
1171523911 524 FT1630 Cut2
1171523911 524 FT1630 Cut3
1171523911 524 FT1630 Sec0
1171523911 524 FT1630 Sec1
1171523911 524 FT1630 Sec2
1171523911 524 FT1630 Sec3
Duncan.
Duncan
Thu Feb 15 2007, 03:59AM
Finally got around to finishing most of the capacitor bank. Here are a few pics:
1171523911 524 FT1630 Mmc0
1171523911 524 FT1630 Mmc1
1171523911 524 FT1630 Mmc2
1171523911 524 FT1630 Mmc3
1171523911 524 FT1630 Mmc4
1171523911 524 FT1630 Mmc5
1171523911 524 FT1630 Mmc6
1171523911 524 FT1630 Mmc7
1171523911 524 FT1630 Mmc8
Duncan.
Duncan
Thu Feb 15 2007, 04:01AM
Finished soldering all the bleeder resistors onto the caps. The cap bank is finished now.
1171523911 524 FT1630 Res0
1171523911 524 FT1630 Res1
1171523911 524 FT1630 Res2
1171523911 524 FT1630 Res3
1171523911 524 FT1630 Res4
Duncan.
Hazmatt_(The Underdog)
Thu Feb 15 2007, 06:27AM
Use the Attachments thread to add pictures, then you can post all your pictures at a later time in the same thread. Otherwise, good job!
Thu Feb 15 2007, 08:58AM
Wow, thats clean. Looks good.
Duncan
Thu Feb 15 2007, 09:10AM
Thanks Hazmatt, I've updated my original posts with proper linked thumbnail pics.
uzzors wrote ...
Thanks uzzors. Yeah the thing I'm trying to do with this coil is make it as nicely made as possible so a) I'll be allowed to keep it in the house, and b) Will hopefully be something cool to look at when it is and isn't powered up.
Duncan.
Duncan
Fri Apr 13 2007, 01:54PM
OK, I've finally gotten around to wiring everything up and giving it a test run. It appears to work well, with streamer length between 30 and 40cm. It does appear that I'll need a toroidal topload, as the spherical one is a bit lacking in terms of shielding. Anyway, here's a couple of pics and a link to a video taken shortly after first light.
1176472455 524 FT20740 Tc1
1176472455 524 FT20740 Tc2
And a short video: Link2
Duncan.
Sat Apr 14 2007, 02:35AM
Nicely done.
Coronafix
Sun Apr 15 2007, 12:42AM
Beautifully neat and effective coil Duncan. smile Can you give
us some specifications on it? What's the transformer rating?
