Registered Member #1565
Hi
I am going to build a +30 kV and -30 kV variable supply.
Currently I am negotiating details with someone who can make the transformers. (if others want the transformers too, please tell.. it helps in getting volume discounts)
Transformer: OEM/Special "flyback" pair (one +30 kV, the other -30 kV), probably driven in half-bridge. Built in temperature sensor Voltage feedback (via internal resistor) Current sensing (external, on board) Shielded 2 meter output cable (shield is grounded) 5 mA output (will ask more around) Primary: 2x12V (for 12/24V supply)
Driver: TL494 with FET-driver if I am going for half-bridge, UC3842 if I am going for flyback instead. May look into more common parts given they can do high+low side FET drive.
Other: Microcontroller to set and messure current limits and voltages. RS485 link for computer control (also useful for whatever other aux board I decide to use, related or not)
Added: Transformer schematic (round ones):
Picture of transformers before shipping:
Update: Getting near actual high voltage test:
Ethernet link works, just need to do way more software on computer and microcontroller.
Registered Member #162
I suspect that over time the eht cables will get shorter and shorter due to different terminations, and are bulky/messy when not in use. If possible/economical, eht terminals/connectors may be better.
To be able to 'play' or experiment at early stages of testing safely, try to minimise or make switchable the output capacitance. doesn't take much capacitance at +/- 30 kV to destroy components or give one heck of a shock !
build in a 'discharge' system
adding a high value/voltage resistance in series with a neon (neon at 0v side, resistor to eht side is easier) across each output gives a visual 'caution' indicator and a small load to make output voltage regulation easier at light loads. (e.g. 10 x 3.5 kV rated 33 MOhm in series = 330 MOhm = 100uA @ 33kV = max. neon current)
Sulaiman wrote ...
Yep, will have to figure out some connection box, but 2 meters cables give some safety distance from supply.
I am looking for some standoffs, maybe the "suction cup" of TV type over the ends joining some HV "outlet".
Sulaiman wrote ...
I plan to have no output capacitance added, anyway, the cable is with grounded shielding so laying the cable over stuff should be no problem.
Sulaiman wrote ...
Actually, the transformer will have a 300 MOhm resistor internally, and I plan to mostly do powered on discharge (monitor voltage as it goes down)
It won't be able to hold a voltage once input power is lost.
THere won't be any unshielded voltages above 48V or so near the controller.
The cheapest eht connectors that I have seen are modified automotive spark plugs. Ceramic eht terminals can be cheap or insanely expensive on eBay.
Re. output capacitance; - none = voltage ripple - stored energy at 31.6 kV = 0.5 mJ per pF (cable etc.) = ouch!
'pro' looking is a key switch to enable and a 'trip' circuit break-to-operate, e.g. hold a n.o. button switch to maintain power, or don't break a thin wire 'barrier' etc. NOT electronically but electro-mechanically where practical. e.g. auxiliary isolated low voltage supply (ac or dc) to a suitable relay coil in series with keyswitch and 'loop' terminals. could be screw terminals or 3.5mm jack etc. normally open Relay contacts in series with output stage power etc..
Update:
Internal resistor: 300 Mega-ohm - confirmed Output current: 10 mA @ 30 kV (300W per transformer) - confirmed System max voltage into isolated load: 60 kV (dual transformer, 600W) - by design Driver topology: 30 KHz half-bridge flyback driver (need to figure out the deal with it) Seller: really helpful
Transformer got built in temperature sensor.
The PCB itself won't have voltages above 30V (safe to touch), input is 12V or 24V.
Made the purchase, agreed on transformer casing/shell type, windings, PCB mounting via through hole.
