  • Guests: 12
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Induction AL coin launcher Help
ljfa321
Sun Feb 26 2012, 01:38AM Print
ljfa321 Registered Member #4455 Joined: Sun Feb 26 2012, 12:49AM
Hi,
I'm working on a AL coin or AL disc flipper kind of design I found a while ago.
Here is the video:
Instead of working like a gun, this just simply flip the coin into the air, and that is all I need.
From the video, it looks like only one disposable camera capacitor was used.
However I was not able to reproduce the result with the same setup (base on what I see in the video since the video is lack of some detail).
Assume he just use the camera as what normally do in a simple coil gun, than the only part I'm not sure about my setup will be my coil.
I'm have tried few coil design; flat one layer disc coil, coil with metal center, and even try to wind the coil messy like in the video.
Can anyone give me a hand here on what I might did wrong? And what's the best way to wind the coil to enable it to flip the AL disc (2cm Diameter, 1g, hopefully can lift up to 10g) high? ( I'm using 22, 26, or 30 gauge magnetic wire, will thicker the better? )
Also, will it help if I use washer type AL disc (with hole in the middle)?
Any help will be appreciated.
Thanks,
Jason
Turkey9
Sun Feb 26 2012, 04:43AM
There's no way he just used one camera battery for that much energy. Most likely it was a bank of five or ten.
Legit_bacon
Sun Feb 26 2012, 05:38AM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
from my experience with washer launchers you should use about ~20 turns of the size of your washer with a hole in the middle
ljfa321
Sun Feb 26 2012, 10:25AM
Turkey9 wrote ...
I'm guessing because Japanese dollar coin is super light, only around 1g.
But more capacitor works for me.
ljfa321
Sun Feb 26 2012, 10:28AM
How about using magnet as projectile?
Is there any setup that can send magnet fly in the air?
Will try to make a simple electromagnet tomorrow and see if I can flip a magnet into the air.
pauleddy
Mon Feb 27 2012, 12:37AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
i have made somthing similar to this it in this post from a wile back
pauleddy wrote ...
ok here is a short video i made, ther is a big magnet, the veiwing film and disk lanching sorry for the lack of sound i was tired and did'nt feel like narrating.
here is a few pics of the guts of it the large switch is to use the terminals on the side.
Th
Th
Th
here is the coil, it did look better when i had a clear CD over it but that brook off so duct tape will do
Th
ljfa321
Mon Feb 27 2012, 06:23AM
pauleddy wrote ...
i have made somthing similar to this it in this post from a wile back...........
Thanks, thats exactly what I want to make, can you tell me what gauge wire are you using, how many layer in the coil, and how many volt in total?
Thank
ben5017
Mon Feb 27 2012, 11:22PM
ben5017 Registered Member #3315 Joined: Thu Oct 14 2010, 04:23PM
does the ring have to be AL? what would happen with a ferris matl.
pauleddy
Tue Feb 28 2012, 12:21AM
that little metal ring is AL but it was just a spacer, umm i don't know if a iron metals will help vary much the pulse time is too quick i think. most non-ferris metals will lanch but AL and CU work the best, the gauge is i think is about 12 or 14??? i will have to check, voltage is what ever the disposible camra chager puts out i think 300-400V, the coil is 2 layers 20 each so about 40 turns. this was a demo device i bult for a science project back in high school that i used a bigger varible disk lancher.
ljfa321
Tue Feb 28 2012, 05:42AM
OK, thank a lot!
