  • Guests: 10
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Arduino as a Coilgun controller?
Legit_bacon
Mon Feb 27 2012, 08:04AM Print
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
Has anyone used a micro controller to control the different systems of a coilgun eg; optical triggering, firing, charging signal, voltage feedback/cutoff?
Also all the control side of things like switches lights etc...
Just wondering if anyone has tried doing this with something like an arduino or other open source micro controller?
-matt.
Forty
Mon Feb 27 2012, 05:52PM
The guy at anothercoilgunsite.com made some impressive coilguns using pic's i believe.
Legit_bacon
Mon Feb 27 2012, 06:57PM
ah yes I remember his famous coil pistol used a pic!
Lekky1
Thu Mar 15 2012, 10:20AM
Lekky1 Registered Member #1592 Joined: Thu Jul 17 2008, 06:58AM
Hi Mattster. I used a Picaxe 20M chip running at 32Mhz for a single stage halfbridge coil gun.
Injector solenoid, charge circuit, voltage monitoring of battery & caps, optical triggering & timing all done by one chip. Worked well.
