  • Guests: 13
Finn Hammer (72)
Blue Adept (43)
Nickel (68)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
"inductor coil" mazzilli driver
tritium
Fri Sept 24 2010, 04:12PM Print
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
Hello everybody,
question about the coil in serie with the mazzilli driver,
should it be iron ore ferrite core, and how much inductance should it be?
I am going to run from 11.1 volts lipo battery 2+2 turns, complete primary coil is 10uH
is it true that the inductance has to be 10 times bigger than the primary inductance?
Fri Sept 24 2010, 07:37PM
This inductor (I'll call it Ldc, dc inductor) in a textbook 'ideal' situation
would have such high inductance that the ac ripple current in the inductor
(due to the waveform at the primary resonant inductor center tap)
is negligible compared to the dc current.
This is why the 'proper' name for a zvs/Mazzilli etc. is Current Fed Parallel Resonant CFPR
A practical Ldc would have to pass the peak current without satuating or overheating
Generally the dc current heats the wire and the ac curent heats the core and the wire
For 10's to 100's of kHz iron powder or gapped ferrite is required. (or air)
As the Ldc inductance is decreased (lower value OR due to saturation)
then the CFPR oscillator moves towards becoming a blocking oscillator,
which may give more output but heat the core(s) too much.
Xplorer
Sat Sept 25 2010, 10:41AM
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
Tritium, I've had good success with a 1in diameter ferrite core wound with 20 turns of 2 strands of 24 gauge magnet wire. I used two strands simply because I didn't have anything thicker.
Although since you're using 4 turns on your primary instead of 10 you may have to try a different number of turns to get ideal operation. I believe that, within limits, the more inductance the higher the output voltage will be at the expense of current and visa versa.
-Tony
Sat Sept 25 2010, 11:08AM
The inductor is just an LF choke. Choose a size that will have sufficient reactance at the oscillator frequency. XL = 2Ï€fL
