  • Guests: 19
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
DRSSTC II - Its Back! Photo
Thu May 04 2006, 05:49PM Print
DRSSTC II - Its Back Photo
Composite Image
Enjoy!
1146764971 15 FT0 Drsstc2 050506a
Marko
Thu May 04 2006, 06:59PM
Is that one that will be used for 'medical' purposes? smile
Cool photo EVR...
Thu May 04 2006, 07:09PM
wrote ...
Gosh, i hope not. Makes trephining look like a walk in the park!
Thu May 04 2006, 09:07PM
EVR can y put the link for the thread where you describe this photo making technique? I remember that I read about this but i lost the text.
Marko
Thu May 04 2006, 09:39PM
I think he just left the camera in place, took several pics with different breakout points and merged them after that.
Note the glowing between metal pipes around coil and earth. I wonder if it is only when arc strikes them or it is result of capacitive coupling..?
Thu May 04 2006, 11:18PM
suprised WOW! I'm afraid for all my technology when I run my coil 20feet from my house, how well do your electronics hold up to that kind of electrical noise? BTW that is one of the most amazing photos I'v seen.
Thu May 04 2006, 11:21PM
The glowing between those pipes and the carpet only occurs during arcing. They pipes are actually PVC scrap wrapped with aluminum tape. And its actually only one pipe, i moved it around from shot to shot.
As far as the technique goes . . .
1. Take several shots on a tripod using same exposure. Take as many as you need.
2. Load the images in Photoshop
3. Copy each image, and paste is as a NEW LAYER in photoshop.
4. Now, for EACH layer, use the LIGHTEN BLEND method on the layer palette. This will basically keep the background unchanged and only add the "light" colors (i.e. arcs) in the image
5. Once its complete, then FLATTEN layers and export to your favorite image format.
GimpyJoe
Fri May 05 2006, 12:41AM
Wow! Did you get any little burns on the walls from that? I had a little SGTC striking the wooden footboard of my bed once, it lit up orange but no visible burns. It was nowhere near that power, though!
Fri May 05 2006, 12:59AM
Thanks. Yeah, i get lots of little pinhole burns in the drywall. No big deal since this is just a storage room. As far as electronics go, i actually have a computer right behind me in those photos which is about 10 feet back from the coil. Never have any problems.
Fri May 05 2006, 01:21AM
Thats amazing. When I run my 1.3kW sgtc it plays havoc with the phones and the TVs. I am too afraid to leave a computer pluged in while im coiling.
