  • Guests: 50
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
Tor (40)
RussT (67)
Stuff (43)
10/31 Tor (40)
10/31 RussT (67)
10/31 Stuff (43)
PIC Interrupts
Turkey9
Wed Mar 17 2010, 05:18AM Print
Ok i'm stumped with this... I'm using a PIC16f690. I'm trying to use TIMER2 to generate an interrupt when ever it matches the PR1 value. This will be used to toggle a pin at around 20kHz in order to drive a flyback. The problem is, no matter what I do, I can't seem to get the code to jump to the interrupt routine! I've set all the bits to enable everything but it's just not working. I know the interrupt routine works as I can set it to interrupt on a pin change and it all works great. I also know the timer is working as I can simulate the code and the interrupt flag bit gets set at the right time and everything. Below is a little bit of the code that I'm using, the important part anyway.
org 0000h
goto    MAIN
org 0004h
bsf  PORTC,5
bcf  PIR1,TMR2IF
RETFIE
Why in the world won't this work? Oh by the way most of this is in MPLAB SIM but it doesn't work in real life either.
Bjørn
Wed Mar 17 2010, 05:29AM
The short answer is that if it does not call the interrupt vector you set it up wrong. Without the rest of the code we have no idea what you did wrong.
Since the chip has a PWM module it can do what you need in hardware which is simpler and more reliable so why not do that instead?
Turkey9
Wed Mar 17 2010, 07:13AM
I need it to run in the background, does the PWM do that? I mean that i can't have it constantly going through delay loops. The code is kinda confusing at the moment because i have goto's isolating the part i'm having problems with, so I'm not going to post it until i clean it up. I know i set bit 6&7 of the INTCON register and bit 1 of PIE1... Also TIMER2 is set to run of the clock and that works great... INTCON is listed in all the banks, does it matter which one i go to to set it? I know that PIE1 is in bank 1, so I just set the INTCON bits there. Am I I supposed to clear the register before setting bits to initialize it or something?
Ok here's the setup portion of the code:
#include <p16F690.inc>
      errorlevel -302
     __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
     org 0000h
	goto	BEGIN
	org		 0x0004
	bsf		 PORTC,5
	bcf		 PORTC,5
	bcf		 PIR1,TMR2IF
	RETFIE
	clrf	         INTCON
	bsf		 STATUS,RP0
	movlw	 0fh
	movwf	 PR2
	clrf	         TRISB
	clrf	         TRISC
	movlw	 03fh
	movwf        TRISA
   	movlw        020h
	movwf        OPTION_REG
	bsf	         WPUA,0&1&2&4&5
	movlw	 02h
	movwf	 PIE1
	bcf		 STATUS,RP0
        bsf		 STATUS,RP1
	clrf	         ANSEL
	clrf	         ANSELH
	movlw	 060h
	movwf	 INTCON
	bcf 	         STATUS,RP1
	bcf		 PIR1,TMR2IF
	clrf	         PORTB
	clrf	         PORTC
BEGIN:
Bjørn
Wed Mar 17 2010, 07:58AM
The PWM unit lets you flip a pin instead of triggering an interrupt so it wil run completely independent of the CPU itself.
Carbon_Rod
Wed Mar 17 2010, 08:47AM
I have not dealt with the 16x690, but I do know a few other chips.
* The init vector is often org 0, but may be in other places depending on the chip
* The reset vector may also move
* Some PICs only have the interrupt on TMR0 overflow
* Some have buggy priority interrupt hardware (18f series)
* PWMs are generally better than interrupts, as you don't have to count machine cycles
(configure internal period & duty, and setup io/module)
The jump vector label BEGIN: skips most of your init code
(unless you are modifying the PC directly someplace else.)
Does this work on the 690?
org 0
goto BEGIN
org 0x0004 ;isr, check flags etc
bsf PORTC,5
bcf PORTC,5
RETFIE
BEGIN:
clrwdt
movlw b'00011110' ; turn wdt off
movwf WDTCON
movlw b'10000111' ; setup pre-scale
movwf OPTION_REG
clrf TRISC
clrf PORTC
clrf TMR0
movlw b'10100000' ; turn on T0IE isr
movwf INTCON
infloop:
nop
goto infloop
Turkey9
Wed Mar 17 2010, 10:17PM
That code does compile but i haven't been able to simulate it yet.
Oh and the BEGIN label is at the beginning of the init code, I just put it in the wrong spot when I copied the code over, sorry!
