  • Guests: 26
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
MD400F720PD1 Plasma Display
Madgyver
Thu Apr 20 2006, 03:57PM Print
I recently obtained a Panasonic Plasma Display for 5 Euro. And I think its rather neat. But I have no Idea about Connectinnbg it/ about the Pinout.
Any ideas?
The Zander
Thu Apr 20 2006, 11:34PM
The Zander Registered Member #295 Joined: Tue Mar 07 2006, 06:59PM
what kind of electronics/controllers were provided with the panel? does it have a model number?
-TheZander
Madgyver
Fri Apr 21 2006, 12:37AM
Here are some Pics.
I actually have no Idea. It seems like their are 12 (2 rows of 6) IC which manage the whole thing.They are REALY large and are connected to the actual DIsplay with some kind of parallel Bus.
1145578517 177 FT1630 Img 0207
1145579582 177 FT1630 Img 0208
[Edit: Thumbnails were broken and linked to themselves.]
Bjørn
Fri Apr 21 2006, 09:51AM
The large chips are probably shift registers. Serial in and parallel out with drivers.
It is not uncommon to find a 12 pin bus on a display, maybe it is compatible with the most common ones for LCDs.
Madgyver
Fri Apr 21 2006, 02:15PM
Sounds good. Additionaly I have found 2 rows of 7 Chips, which are also connected to the display like the 12 other. But these are much smaller.
the big ones are SN755118PA
the small ones are SN751506FT
I will study more...
Experimentonomen
Tue Dec 02 2014, 06:47PM
Helloooooo!!
Im waking up this old thread after eight years of slumber.
Did you ever get anywhere with this display ? I aquired one today and have been googling my dick off tryiong to find atleast a pinout on the controller ic SN751521GAFT, i've found out throubg the manuals for the toshiva T3000 series portables what signals the thing expects, but not which pin is what signal.
Shrad
Tue Dec 02 2014, 08:04PM
have a look at contacting a chinese manufacturer from those selling cheap LCD controllers, mentioning a connector like that one...
last time I had to research small LCD touchscreens which came without datasheets, and had a ribbon which was identical between brands... I had a look at ebay, and sent a message to ask if those panels were supported, and voila instant pinout and equivalents
Experimentonomen
Tue Dec 02 2014, 08:12PM
Although this is not a LCD panel, and i have more or less confirmed its just your bogstandard CGA input, but with the addition of a data shift/pixel clock.
Experimentonomen
Wed Dec 03 2014, 08:36PM
I think i have this thing figured out now, it has two 4bit parallel buses offering two levels of grayscale.
A video: Link2
Next step is having the arduino generate some 4bit parallel data to write something on the screen other than just generating H and V sync.
Experimentonomen
Thu Dec 04 2014, 03:30PM
Tied the four data inputs together and fed them the vsync signal inverted throigh a 7414: Link2
