  • Guests: 18
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Image Correction Software
Sat Dec 05 2009, 09:06AM Print
The initial problem-
I have a text book that was provided to us as an unbound pile of pages (I suppose that $80 just doesn't go as far as it used to...), which is inconvenient to use.
The initial solution-
Run the book through a scanner (HP C7190) I found in the trash pile at school, using the auto paper feeder (C5195) on it, using the xsane tools under linux (since from what I have heard, these scanners are iffy at best to support under a modern windows install). That all works fine and dandy and I can load a 30 page stack into the printer and get 30 png files out 10 minutes later.
The new problem-
The CCD on the scanner has some hot and dead pixels, which cause streaks through the image. I am not sure if that was the best that $800 could do back in the 20th century or if the sensor has since degraded over the last decade, but in any case I want to try and clean them up a little bit. It seems like this is the process that astronomers use. I envision a piece of software that I can feed a white image and black image to for it to map out the bad pixles, and then a directory with 2000 png files and come back in a few hours with a directory of corrected files.
Does such a piece of software exist? I have been looking and short of a few buyware programs, I have found pixelzap which seems close to what I want, but it only appears to deal with hot pixels, and looking at my scans I think I have some dark pixels as well.
Here is a picture of a white piece of paper that was scanned to give you an idea of what I am working with
1260003962 56 FT0 Out
Thanks!
Sat Dec 05 2009, 10:13AM
Have you tried opening the scanner up and blowing dust out of it? Those dead pixels might just be lumps of dirt in the optics. I spotted one that changes colour and disappears, which is surely impossible if it's a real dead pixel...
Bjørn
Sat Dec 05 2009, 03:09PM
That is common for uncalibrated CCD chips, even space probes with carefully selected chips have those problems. Usually the firmware in the scanner or the driver will fix it by scanning a neutral area utside the scanning window.
Unless the paper got stripes you have some electronic interference too.
I write programs to solve such problems for fun so I might be talked into giving it a go. Try to upload a white page and a page with text in .png format, that should be enough to make a quick test.
Sat Dec 05 2009, 06:40PM
The first thing I tried was giving the scanner a good dusting, and while I managed to get a few stripes to go away I didn't have much luck.
I never considered that it might be EMI, it wouldn't surprise me if there is a leaky cap or the likes in it that is causing the issues.
What I do find interesting is that the scans I took this morning seem noticeably better than the ones taken last night, although they still aren't really that great. I am starting to wonder if there is some kind of heat related issue or if the sensor calibration is set to only make small corrections, so it has slowly been improving as I make scans.
1260037007 56 FT80625 Title0014 1260037007 56 FT80625 Title0015
Bjørn
Mon Dec 28 2009, 05:06AM
Everything take 10 times as long when using only one arm so I did not get around to look at this before now. The stripes are not very consistent so I took the calibration data from the bottom of the same page.
This was my first attempt and it turned out quite well.
1261976767 27 FT80625 Processed
Andri
Mon Dec 28 2009, 07:08AM
Andri Registered Member #1533 Joined: Wed Jun 11 2008, 02:13PM
I've heard that old scanners sometimes need to be "warmed up". This problem seems to have been solved but in case you run into problems like this in the future, I'd like to point out the fft feature in ImageMagick Link2
Anyway, that's not really relevant since the problem can be solved by simple contrast manipulation. Using the command:
$ convert -level 0%,55% -normalize -colorspace Gray -scale 50% 1260037007_56_FT80625_title0015.png out.png
on the picture from the second post yields this
1261982998 1533 FT80625 Out
I wrote a script the other day which merges a group of images and fixes the contrast and then merges them into a pdf file. Link2
Good luck!
Bjørn
Mon Dec 28 2009, 11:33AM
Here is the program I used, if someone can make a portable version in Python I would be very interested. If something looks strange in the code it is most likely the forum parser that is messing up the text.
Dim gr As Graphics
Dim bmdR As System.Drawing.Imaging.BitmapData
Dim pictureArray() As Byte
Dim Picture1, Picture2 As Bitmap
Dim red, green, blue, x, y, offset, frameSize, bytesPerPixel, calibrationN, calibrationY As Integer
Dim rCalAverage, gCalAverage, bCalAverage As Single, rCalibration(8192), gCalibration(8192), bCalibration(8192) As Single
calibrationN = 300
calibrationY = 2500
'Load and display picture
Picture1 = New Bitmap(My.Application.Info.DirectoryPath & "/stripe1.png")
PictureBox1.Image = Picture1
Application.DoEvents()
'Convert picture format if needed
Select Case Picture1.PixelFormat
    Case Imaging.PixelFormat.Format24bppRgb, Imaging.PixelFormat.Format32bppArgb, Imaging.PixelFormat.Format32bppPArgb, Imaging.PixelFormat.Format32bppRgb
        'Nothing to do here, this is our native format
    Case Else
        'Convert all other formats to our native format of RGB 8 bit per primary colour
        Picture2 = New Bitmap(Picture1.Width, Picture1.Height, Imaging.PixelFormat.Format32bppArgb)
        gr = Graphics.FromImage(Picture2)
        gr.DrawImageUnscaled(Picture1, 0, 0)
        Picture1 = Picture2
End Select
'Move the bitmap into a byte array for easy access
bmdR = Picture1.LockBits(New Rectangle(0, 0, Picture1.Width, Picture1.Height), System.Drawing.Imaging.ImageLockMode.ReadOnly, Picture1.PixelFormat)
frameSize = bmdR.Stride * bmdR.Height
ReDim pictureArray(frameSize)
System.Runtime.InteropServices.Marshal.Copy(bmdR.Scan0, pictureArray, 0, frameSize)
Picture1.UnlockBits(bmdR)
'Extract calibration data
bytesPerPixel = System.Drawing.Image.GetPixelFormatSize(Picture1.PixelFormat) >> 3
For y = calibrationY To (calibrationY + calibrationN) - 1
    offset = bmdR.Stride * y
    For x = 0 To Picture1.Width - 1
        rCalibration(x) += pictureArray(offset + 2)
        gCalibration(x) += pictureArray(offset + 1)
        bCalibration(x) += pictureArray(offset)
        offset += bytesPerPixel
    Next
Next
'Average each calibration channel
    rCalibration(x) /= calibrationN
    gCalibration(x) /= calibrationN
    bCalibration(x) /= calibrationN
    rCalAverage += rCalibration(x) / (Picture1.Width - 1)
    gCalAverage += gCalibration(x) / (Picture1.Width - 1)
    bCalAverage += bCalibration(x) / (Picture1.Width - 1)
Next
'Subtract the average so that there will be no colour or brightness change of a line
    rCalibration(x) -= rCalAverage
    gCalibration(x) -= gCalAverage
    bCalibration(x) -= bCalAverage
Next
'Subtract the calibration data from every line in the picvture
For y = 0 To Picture1.Height - 1
        red = pictureArray(offset + 2) - rCalibration(x)
        green = pictureArray(offset + 1) - gCalibration(x)
        blue = pictureArray(offset) - bCalibration(x)
        pictureArray(offset + 2) = Math.Max(Math.Min(red, 255), 0)
        pictureArray(offset + 1) = Math.Max(Math.Min(green, 255), 0)
        pictureArray(offset) = Math.Max(Math.Min(blue, 255), 0)
    Next
Next
'Move byte array back to the bitmap and display picture
bmdR = Picture1.LockBits(New Rectangle(0, 0, Picture1.Width, Picture1.Height), System.Drawing.Imaging.ImageLockMode.WriteOnly, Picture1.PixelFormat)
System.Runtime.InteropServices.Marshal.Copy(pictureArray, 0, bmdR.Scan0, frameSize)
Picture1.Save(My.Application.Info.DirectoryPath & "/processed.png", System.Drawing.Imaging.ImageFormat.Png)
Sun Jan 03 2010, 11:22PM
Thanks for the input guys, these results are looking very promising! I have been busy over the last month or so with Christmas break, but hopefully now that school has started I can spend some time thinking about how to best tackle the issue, I will keep you posted of any progress.
As to the warming up, the results definitely get better with time, but the images shown are after sitting overnight powered up (this scanner runs the tube CCFL tube at all times while powered up, probably to solve the warmup issue). The variation in the stripes definitely leads me to think it is heat related, although I still suspect it may be related to some of the caps getting old and leaky/high resistance.
Bjørn
Tue Jan 05 2010, 10:12PM
I have added automatic detection of the most suitable lines for the calibration data and a median function so it discards any spots. With multithreading it processes two images per second on a fast PC, most of the time is spent on compressing the huge .png files.
Arkin
Fri Jan 08 2010, 11:14PM
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
Also, XSane scanner has alot of options. You can take a preview scan, tell it which what scanned color is really white, gray, and black. It should automatically correct the scan.
Set the scan to binary (Black or White), and you should have a usable scan.
