  • Guests: 15
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
3310 screen hackery
Tue Dec 01 2009, 07:17PM Print
Hi all.
I finally managed to aquire through questionable means wink a 3310 and a 3330.
The former does not turn on due to water damage but the screen appears undamaged and it did work a while ago when I last used it.
The connector is of the "sprung" variety so first step will be soldering on some wire posts so it will fit on my protoboard.
has anyone else here ever played with these beasties?
micro i am looking to use them on is a PIC 12F683 (675 with more RAM)
thanks, -A
Bjørn
Tue Dec 01 2009, 08:42PM
The SPI ones are easier than the old type with I2C. They are all fairly similar so some of the ideas work on most of them. You must get the voltage/contrast registers set up properly or there will be no picture, once you got that working it is just a matter of pushing the bitmapped data.
I used some of the Nokia information to get my Siemens display working. I soldered to the springs and covered them with glue to keep everything in place, it is easy to rip the connections off the glass.
Dago
Wed Dec 02 2009, 09:28PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
I've used the SPI ones and they are easy to interface but I do NOT suggest soldering to the contacts. At one point I had like three displays soldered and NONE of them were working consistently, just randomly. I think the plastic block holding the contacts melts and the contacts get loose or they just simply do not push against the contacts in the glass. But I finally made an adapter which does not require soldering (just an etched PCB board) and it works 100% of the time.
Mon Dec 07 2009, 01:07PM
I've played with a 3310 screen and AVRs. I just soldered some ribbon cable on it so it fits on my STK500 board, and found a 3310 library for AVR-GCC. Since then it's been a breeze to use.
