  • Guests: 19
Steve Conner (46)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Help function & Outlook very slow on laptop
Alfons
Mon Apr 17 2006, 11:46AM Print
Alfons Registered Member #134 Joined: Fri Feb 10 2006, 10:44PM
Hi,
When I push F1 to see the Help-function of a certain program (any program with a *.CHM help file), it takes minutes for my laptop to open it.
Also, when I open Outlook 2003, it takes a very, very long time to open messages or to browse the folders.
My laptop is quite fast (Acer Aspire 3005WLMI with Sempron 3300+, 512MB RAM) so I find it very strange that it takes so long to open the program / files.
Does anyone have any idea how to fix this problem?
Bjørn
Mon Apr 17 2006, 01:00PM
Both probably use the explorer HTML/XML functionality. Maybe you have contracted some sort of spyware.
Alfons
Mon Apr 17 2006, 01:05PM
I'm quite sure that that isn't the case, since it already happened just after reinstalling windows using the laptop's recovery cd's.
I scanned for viruses and spyware to be sure, and none was detected.
Bjørn
Mon Apr 17 2006, 02:05PM
Can you find out what process that is spending the time and if it uses CPU time? Is there any disk access? Do you have the latest drivers for everything installed and disabled any network devices that is not in use?
Alfons
Mon Apr 17 2006, 02:21PM
According to Windows' taskmanager, OUTLOOK.EXE, WINWORD.EXE (while Word ISN'T running) and svchost.exe require the most Mem, while System Idle Process and rundll32.exe require the most CPU.
No, the disk-activity LED isn't illuminated.
At least I think so, yes.
What exactly do you mean? I do have a non-connected LAN-port, which is 'disconnected' but not 'disabled'. My wireless LAN is connected, though.
FastMHz
Mon Apr 17 2006, 05:33PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
It's possible that your swap file is too small and Windows is having to enlarge it, which is slow.
Go into System properties, click Advanced tab, click Settings under Performance, select Advanced tab, and Change for virtual memory. Select Custom Size and enter the same value in both minimum and maximum boxes. Try 768mb at first, and if you get out of memory errors, up it to 1024mb.
You should also try clearing your IE cache and defragging .
Alfons
Mon Apr 17 2006, 06:43PM
No, that doesn't seem to be the problem; only about 300MB of the pagefile is being used while opening an Outlook message or a Help-page.
That didn't help either, unfortunately.
Mon Apr 17 2006, 10:46PM
It could be that you set your message editor in outlook to me M$ word... Loading word is what is taking a ton of time. The setting is hidden in the menus somewhere, chang it to the outlook one and see if that helps.
As to the f1 thing, it is a pretty common thing for that to take a while, I think it is compressed or something and loading it takes a while. I haven't found a way arround that, Minutes does seems a little excessive though...
Alfons
Tue Apr 18 2006, 09:23PM
Done.
It helps a little bit; messages now only take 1 minute to show up instead of 10 dead
Thanks anyway for the advise.
