  • Guests: 31
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
strange arc appearance
Mon Feb 13 2006, 03:15PM Print
hi, my 1st post there smile
I was playing with a small DC flyback from old photocopier and noticed something strange (at least for me): when the arc is short (ie 5mm), half of the arc looks "normal" (purple) while the other half (closer to the HV wire) is nearly dark, only with faint blue glow. Just the tip of the HV electrode glows.
The flyback was running at very low power (about 10w).
Attached is a pic of the arc. Sorry for the crappy pic, I took it with my phone
(Yes, the arc in the picture is really an arc / not corona)
1139843667 152 FT0 Strangearc
Mon Feb 13 2006, 03:31PM
Arc can be affected by geometry and/or material of the discharge point. Also, if you were arcing from +HV to GND (RTN), this can affect appearance also.
Without a better photo, its hard to say whats going on.
Mon Feb 13 2006, 05:27PM
ok I tried o get a better picture but I am really an expert in getting blurry pictures dead (with flash it was better but the arc was nearly invisible in the strong flash). I changed both electrodes to copper wire, but it still looks the same.
Here is a link to the pic http://www.volny.cz/jmartis/arc_new.jpg
The red wire is HV from flyback and the white is GND.
(the arc looks blue in the photo but it is actually purple)
Mon Feb 13 2006, 05:45PM
So, you are basically saying you see more corona on one side of the wire, than the other?
Corona does form differently on electrodes depending on which one is more positive. Corona can also take different coloring depending on the polarity as well. This is well documented in many different hv texts including High Voltage Engineering by Kuffel and Zengl.
Mon Feb 13 2006, 05:59PM
As I said in my first post, it is not corona, but arc. When I open the gap, and start moving the electrodes closer, at first occurs corona (which is assymetrical BTW, and I know it's normal), then sparks start to jump, their frequency increases until they change into continuous silent arc. I'm pretty sure that it is an arc because it can melt plastic and set a paper on fire. That's why I was wondering about it because I saw this effect with DC corona but not arc.
Mon Feb 13 2006, 09:20PM
wrote ...
Thats normal and i would expect that to happen.
Mon Feb 13 2006, 09:52PM
EastVoltResearch wrote ...
wrote ...
That was not my point, I just want to know why the arc looks so strange (normal purple in one half and nearly invisible in the other).
Sorry, I didn't want this dialog to go so far... 8-o
Mon Feb 13 2006, 11:14PM
I think the arc is vapourising the copper
copper ions are positive
so they will be repeled from the +ve wire into the arc
excited copper ions give Green light.
the negative electrode/wire probably gets blackened with copper-oxide.
Overall bluish light comes from Nitrogen ions.
Tue Feb 14 2006, 04:06PM
Sulaiman wrote ...
Hi Sulaiman, thx for your reply,
I've also tried steel wire and aluminium foil, but the arc looks exactly the same, so I think it has nothing to do with the electrode material. I can also take a video of it, but with my skills with a camera, it won't be of very high quality.
I looked closely at the "dark space", and it looks like the arc is wholly transparent here (not even blue).
Electroholic
Fri Feb 17 2006, 03:16AM
I think I know what you are talking about.
My mini marx made the same kind of arc, but it only happens when running at low power.
