  • Guests: 62
Ed (49)
JC1 (49)
06/16 Ed (49)
06/16 JC1 (49)
06/17 Th3_uN1Qu3 (33)
Kaizer DRSSTC I
first  3 4 5 6
Sat Nov 06 2010, 08:19PM
5th November 2010
150 centimeter long sparks! Running from 250VAC in at 10A, 9 cycles ~200-225uS on-time, 500A limiter.
1289074645 1403 FT1630 Img 2669
1289074645 1403 FT1630 Img 2833
Sat Nov 06 2010, 08:22PM
That's a very good result for so little primary current. Job well done :) Now you just need a second one running out of phase wink
Dr. H.
Sat Nov 06 2010, 09:36PM
Beautiful work Mads ! Love that ground spark smile
Sat Nov 06 2010, 09:59PM
Thanks guys :)
I actually did plan from the start to build twins, but might upgrade the silicon first... and use this bridge in a smaller coil.
I got a video of the stress test uploaded, rest will have to await time for editing :)
Coronafix
Sun Nov 07 2010, 11:36AM
Looks good Mads, but mind those racing sparks. They can damage your secondary.
Sun Nov 07 2010, 01:25PM
Coronafix wrote ...
I am aware of the problems, I need to make a ring to put under the secondary to lower the coupling. Some of the strikes are directly from the topload to the strikering, the topload is not completely smooth... so they will occur.
Luca
Sun Nov 07 2010, 03:24PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Good results Mads!
I wonder if you trip your OCD frequently or not, since 500A seems to be quite a low value given the size of your coil...
Regards,
Luca
Sun Nov 07 2010, 09:14PM
Luca wrote ...
Good results Mads!
Regards,
Luca
The OCD is only tripping at ground strikes or high BPS, I am not going over 500A limit due to experience from other forum users with the IXGN60N60C2D1 IGBTs.
I will eventually upgrade the bridge with CM300.
Mon Nov 15 2010, 10:21PM
I have added all the relevant pictures of the construction of the coil and much more spark pictures to my site: Link2
Hopefully I will soon be able to do the first midi test and a upgrade of the bridge might just be around the corner... :)
Goodchild
Sat Nov 20 2010, 05:30AM
Ive been following your build for a while now and I must say fantastic work.
Just wanted to offer some input, you may benefit from a flat primary. I started with a helical primary
on my first DRSSTC and had similar problems with racing sparks and toroid to strike rail arcs. I switched
to a flat primary and all of these problems were eliminated.
Ether way great performance at 500A primary current! Keep up the great work.
first  3 4 5 6
