  • Guests: 56
GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
VB6 Month Timer Help
john bunsenburner
Mon Aug 10 2009, 11:09AM Print
john bunsenburner Registered Member #1937 Joined: Sun Jan 25 2009, 12:28PM
I have been designing a program, just for fun, part of it involves counting months, simply adding 1 to a label's caption every time a month passes. The problem is the fact months tend to vary in length, and because this should be fairly accurate(and no, leap years are no problem, I will deal with those my self) at any given time i have tried to code the program in a manner in which each month is treated separately, now without further ado, I'll just give you guys the code.
Private Sub Form_Load()
Timer1.Enabled = True
End Sub
Private Sub Timer1_Timer()
Label1.Caption = (Label1.Caption + 1)
Lbl1.Caption = (Lbl1.Caption + 1)
If Label1.Caption = 60 Then
Label2.Caption = (Label2.Caption + 1)
Label1.Caption = 0
ElseIf Label2.Caption = 60 Then
Label3.Caption = (Label3.Caption + 1)
Label2.Caption = 0
ElseIf Label3.Caption = 24 Then
Label4.Caption = (Label4.Caption + 1)
Label3.Caption = 0
ElseIf Lbl1.Caption = 604800 Then
Label5.Caption = (Label5.Caption + 1)
Lbl1.Caption = 0
ElseIf Label4.Caption = 31 Then
Label6.Caption = (Label6.Caption + 1)
ElseIf Label4.Caption = 59 Then
Label4.Caption = 0
ElseIf Label4.Caption = 90 Then
ElseIf Label4.Caption = 120 Then
ElseIf Label4.Caption = 151 Then
ElseIf Label4.Caption = 181 Then
ElseIf Label4.Caption = 212 Then
ElseIf Label4.Caption = 243 Then
ElseIf Label4.Caption = 273 Then
ElseIf Label4.Caption = 304 Then
ElseIf Label4.Caption = 334 Then
ElseIf Label4.Caption = 365 Then
Label6.Caption = 0
Label4.Caption = 0
End If
End Sub
Label4 displays days
Label6 months
The problem is once the day counter hits 31, the month counter goes up in seconds. Timer interval is set as 1second(1000ms). I realize the problem is caused by the day timer to sty on 31 for 24hours, thus the month timer adds 1 every second for 24 hours, this could be solved by using seconds instead of days but that would leave me with big numbers, so i ask if there is any alternative solution.
Thanks in advance!
Nicko
Mon Aug 10 2009, 11:26AM
At first glance the problem is probably that use are using "elseif" everywhere, and in timers like this you need to ripple-through the changes.
e.g.
Initialisation:
Dim nDaysInMonth as Integer = new Integer(12) {31,28,31,30,31,30,31,31,30,31,30,31}
    ' If leap year, adjust Feb
    ' (syntax depends on VB version)
    ' True if it is divisible by 4
    ' False if it is divisible by 100
    ' TRUE if it is divisble by 400
    ' intYear is the current Year as an Integer!!
If ((intYear Mod 4 = 0) And (intYear Mod 100 <> 0) Or (intYear Mod 400 = 0)) Then
    nDaysInMonth(1) = 29 / Feb is a leap year!
EndIf
Label4.Caption = 1 // First day of Month
Label6.Caption = 1 // First Month of Year
...etc...
rem note Label4.caption is always one less than correct date
    Label1.Caption = 0
EndIf
    Label2.Caption = 0
EndIf
    Label3.Caption = 0
EndIf
If Label4.Caption > nDaysInMonth(Label6.Caption - 1)  Then
    Label6.Caption = Label6.Caption + 1
    Label4.Caption = 1 // First day of next month
EndIf
If Label6.Caption > 12  Then
    ' ...its another year
    Label6.Caption = 1
EndIf
...etc.
Also, there are 86400 seconds in a day (not sure what magic numbers you are using or even why).
HTH
LithiumLord
Mon Aug 10 2009, 11:30AM
woah-woah-woah! Hold on, are you making just a counter that, once started, counts full running time?
Static Init As Variant, InitDay As Integer, InitMonth As Integer, InitYear As Integer
If Init = "" Then
Init = Time
InitDay = Day(Date)
InitMonth = Month(Date)
InitYear = Year(Date)
End If
Label1.Caption = "Running: " & Year(Date) - InitYear & " Y " & Month(Date) - InitMonth & " M " & Day(Date) - InitDay & " D " & Format(Time - Init, "HH:MM:SS")
End Sub
john bunsenburner
Mon Aug 10 2009, 07:42PM
Hey thanks for the help, I ajusted the code so that only the month part uses else ifs, then i read this...604800 is seconds in a week.
Yes im making a counter that simply counts seconds,minutes,hours,days,weeks, months and years from the time it is started, this will then be used for the rest of the program.
I didn't know VB had a built in system clock, it would of spared me lots of work, but now where i started it this way, might as well continue similarly.
Really the code you supplied will need close studying by me, so i might ask dumb questions later on, or use a, far less efficeint meathod of doing it, if I do it, might as well do it my self.
If we foget about leap years, how would the code look(the Dim statement is new to me, i understand what is being done, but not exactly how)
I greatly appriciate your help, and ask you to bare with me until I manage to grasp hold of VB. Maybe i'll come up wiht something intresting for you guys some day.
Again thanks a bunch, and see you round!
LithiumLord
Mon Aug 10 2009, 11:47PM
Sry I left that "d" var as I expected to use it but never did :P
Anyway, for a meter that's independant of the system time tweaks and that uses a fixed week/month/whatever length as is common for exact measurements, also has an mS accuracy:
'initialize the variables
Dim t As Single, pt As Single, Days As Integer
Const MaxIncrement = 100 'sanity limit ;)
'initial setup
pt = Timer
End Sub
Private Sub Timer1_timer()
'midnight
If pt > Timer Then pt = 86400 - pt
'increment
If Timer - pt < MaxIncrement And Timer - pt > 0 Then
t = t + Timer - pt
Else
t = t + Timer1.Interval / 1000
End If
'sync time
pt = Timer
'all the output code should be ran after this fast bit
'here we go with a sample code, splitting our single time accumulator in two to increase the capacity:
Days = Days + Int(t / 86400)
t = t - Int(t / 86400) * 86400
'this sets the program duty limit to the max integer days, that's kinda much ;)
'No need to keep splitting as the max day length is 86400 seconds which fits the Single type var's capacity
'btw - this splitting method is a good example of how it works - even with a few days increment it will still work out ;)
'Now, let's do some output examples. This is a simple one:
Label1.Caption = Days & " Days " & Format(Int(t) / 86400, "HH:MM:SS") & "." & Int((t - Int(t)) * 1000)
'Here we use that 86400 divider in order to be able to use the Format function right, and the rightmost bit is for mS display
'ok, now I'll show you how you can split the time using fixed month, week and year length
Label2.Caption = Int(Days / 8)
Label3.Caption = Days - Label2.Caption * 8
Label4 = Int(t / 3600)
Label5 = Int((t - Label4 * 3600) / 60)
Label6 = t - Label5 * 60 - Label4 * 3600
End Sub
'Kinda easy, huh? Now for the fun stuff:
Private Sub Command1_Click()
MsgBox Int(Days / 8) & " Weeks" & vbNewLine & Days - Int(Days / 8) * 8 & " Days" & vbNewLine & Format(Int(t) / 86400, "HH:MM:SS") & "." & Int((t - Int(t)) * 1000), vbInformation, "Running time"
End Sub
This needs a form with a timer with any interval, labels and a command button, the MaxIncrement constant at the beginning is used for the system time setup: should a time setup happen it checks if the incremention value which has a very high accuracy as just a few directives are ran in between the points gets above the set value and if so, it uses the timer's interval value instead of the measured delay. The midnight-point compensation is there btw. It is set in seconds and represents the max allowed increment.
john bunsenburner
Tue Aug 11 2009, 08:29AM
Wow, thanks alot mate, this looks great, and somewhat simple. Ill go about understaning all of it, then i will use it. Thanks alot, your a great help.
I am a little confused at the meanign of pt and t
Also why are days/8 in the end?
LithiumLord
Tue Aug 11 2009, 10:05AM
I got a bit messed myself, of course /7 (lol, night-time coding :)). That's an example of a weekly counter, that uses the first division to count weeks and then multiplies it back (it's an integer now, see? ;)) and trims the needed number of days from the counter to count the remaining days that do not form a full week.
t is the accumulator, and pt is the delta.
Tue Aug 11 2009, 11:34AM
The solution to the original problem (months count up in seconds) is to keep a record of what each variable was the last time you checked it, and then do something like the following for each test:
If (day is 31 AND day was not 31 the last time I checked)
then do stuff
else do nothing
Of course it's much easier to use the system clock as LithiumLord points out :) It already knows leap years, the numbers of days in each month and so on.
john bunsenburner
Tue Aug 11 2009, 08:51PM
Does this solve the problem:
LithiumLord
Tue Aug 11 2009, 10:12PM
Well, I see whole three downsides in the code shown. First of all, there's no point in using control properties as shared vars if you can just declare a few shared vars ;) Then - there's no reason to use such a distributed code as you can just implement sequential splitting as in my version, eg via that Int/division trick. And next - the code execution takes time, and it will make the delays inaccurate, also keep in mind there's no reason in using different year/month length as we are making a differential measurement and therefore need no calendar dependancy - or it would be mess like in physics a light year would be different for different years ;)
