  • Guests: 38
Timo (40)
01/05 Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
Julia set in Java
Myke
Tue Jun 09 2009, 05:14AM Print
Hi. I tried coding up a program to render a Julia set given the complex number c. For some reason, the code's algorithm always escapes to infinity leading it to plot no points in the window. Can someone look over my code and try to find what is causing it to do this?
import gpdraw.DrawingTool;
import gpdraw.SketchPad;
public class JuliaSet {
	private double Cre, Cim;
	private double newRe, newIm, oldRe, oldIm;
	private int a = -100;
	private int b = -100;
	private int maxIterations = 150;
	SketchPad paper = new SketchPad(200, 200);
	DrawingTool pen = new DrawingTool(paper);
	public JuliaSet(double re, double im) {
		Cre = re;
		Cim = im;
	public void render() {
		for (int re = a; re <= 100; re++) {
			for (int im = b; im <= 100; im++) {
				newRe = re / 100.0;
				newIm = im / 100.0;
				int k;
				for (k = 0; k < maxIterations; k++) {
					oldRe = newRe;
					oldIm = newIm;
					newRe = oldRe * oldRe - oldIm * oldIm + Cre;
					newIm = 2 * oldRe * oldIm + Cim;
					if ((newRe * newRe + newIm * newIm) > 100)
						break;
				if ((newRe * newRe + newIm * newIm) <= 4)
					pointAt(re, im);
	public void pointAt(int x, int y) {
		System.out.println(x + " " + y);
		pen.up();
		pen.move(x, y);
		pen.down();
		pen.move(x + 1, y);
	public static void main(String[] args) {
		JuliaSet set = new JuliaSet(1, 0);
		set.render();
EDIT: Nevermind, I got it working and here is the working code: (I still need to implement the color part of the fractal)
import java.awt.Color;
	private int a = -800;
	private int b = -800;
	private int maxIterations = 256;
	private double zoom = 400;
	SketchPad paper = new SketchPad(1600, 1600);
		Cre = re;
		Cim = im;
		for (int re = a; re <= Math.abs(a); re++) {
			for (int im = b; im <= Math.abs(b); im++) {
				newRe = re / zoom;
				newIm = im / zoom;
				int k;
					oldRe = newRe;
					oldIm = newIm;
					if ((newRe * newRe + newIm * newIm) > 4)
						break;
					pointAt(re, im);
//				else
//					pointAt(re, im, new Color(Color.HSBtoRGB(k/(float)maxIterations, 1, 1)));
		System.out.println("DONE RENDERING");
		pen.up();
		pen.move(x, y);
		pen.down();
		pen.move(x + 1, y);
//	public void pointAt(int x, int y, Color col) {
//		System.out.println(x + " " + y);
//		pen.up();
//		pen.setColor(col);
//		pen.move(x, y);
//		pen.down();
//		pen.move(x + 1, y);
		JuliaSet set = new JuliaSet(-1, 0);
		set.render();
And here is a screenshot of the julia set for when C = -1.17-1.6i:
6i Julia Set
Arkin
Sat Jun 13 2009, 02:20AM
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
Just a quick tip, You use this code:
int k;
for (k = 0; k < maxIterations; k++) { ...}
But you can do:
for (int k = 0; k < maxIterations; k++) { ..}
Pointless, but keeps it more organized :).
You should also learn to use the Graphics Method (for applets, but you can do standalone applets also). Much more flexible, and very easy.
Myke
Sat Jun 13 2009, 08:31AM
I am going to be using AWT for rendering. Also, I initialized k outside of the loop so that I could use the max number of times that it had iterated to determine the color that I should set it outside the set (probably am going to move it to being initialize it with all the other fields...).
