  • Guests: 29
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Class E Circuit
ragnar
Fri Apr 07 2006, 07:24AM Print
My lil crappy class-E circuit.. coming soon =)
That waveform is overdamped with a capital 'F' - I've just found my 'smaller capacitors' box, so I'll post more pics tonight when I replace my blown components. Tee hee.
1144394684 63 FT0 Classe5
1144394684 63 FT0 Classe2
Desmogod
Fri Apr 07 2006, 07:44AM
What does class E plasma look like in a plasma globe?
WaveRider
Fri Apr 07 2006, 08:27AM
Hi BP..
Are you operating below resonance?
Here's my latest result..
1144398387 29 FT6870 Dsc01050s
This was done with a simple variation of the Armstrong oscillator. (Single-sided cousin of Royer.. wink )
Dr. Shark
Fri Apr 07 2006, 11:45AM
Hey, you are getting exactly the same crap that I get in my class E circuit! Exponential ramp which crashes down as the FET switches, instead a a nice, smooth damped oscillation. I have not worked on my circuit lately because first I was out of parts and then I got ill, but I'll try some more class E-ing soon.
Its a shame that Richie Burnett, the father of the Class E SSTC is not on this board!
Fri Apr 07 2006, 12:01PM
I know, I've tried to get him to join :P He explains how to tune a Class-E SSTC on his site anyway:
You adjust the primary turns, coupling, and shunt capacitor by trial and error until the waveform looks right, then turn up the power a bit and adjust it all again (since the corona loading is non-linear) Repeat until you're running at full power. It's tempting to use a ham radio antenna tuner to make the adjustments easier. I would use an air-spaced variable capacitor out of an old radio as the shunt cap at least.
I say BP needs looser coupling and a smaller shunt capacitor.
WaveRider
Fri Apr 07 2006, 12:30PM
Judging by the snippet of your primary in the photo, I'd agree with Steve. I used only 4 turns in my primary...you have lots!
By doing the Spice simulations, I was able to establish that a coupling coefficient of about k=0.18 and a 180pF shunt cap (given by my modeling of the coupled resonator-primary system) yields the desired waveforms at 4.7MHz with my choice of transistor. Your situation will vary, based on resonant frequency, transistor and choice of DC voltage supply.
In short, I did trial and error using Spice to find the right capacitor value, and found the sims to be pretty much spot-on when I cobbled together the working model...
Good luck!
Dr. Shark
Sat Apr 08 2006, 02:41PM
Steve Conner wrote ...
I know, this is what I would do when I was at least somewhere near the desired oscillatory waveform. One could make a small change and see if it gets better or worse. But in this situation, where the waveform is completely off, it is really hard to tell if some change makes it better or worse. I even emailed Richie about it, but his reply did not help much.
Btw, according to Link2 you can get rid of the shunt cap completely if your FET can stand the voltage spike, and I tried that (removed it completely) without any benefit. Back to the shop...
Edit:
1144510947 75 FT1630 Dscn4128
getting classy here...
now if I just knew how to get the drain voltage to rise right after the FET switches off, and not only when it is just about to turn on again, I'd be a happy guy.
Another peculiar thing that is definitely worth menioning: I am driving the coil at exactly half the resonant frequency. The calculated f_0 is 3.6MHz, the driver runs at 1.8MHz. I do not know if this is possible at all, but it seems to produce sparks smile
Sat Apr 08 2006, 04:22PM
I just got this from Richie-
Richie Burnett wrote ...
I took a look on 4HV and saw the thread you told me about. I think the
reason why those people are having trouble getting the correct drain
waveform might be because they are trying to use feedback to make the
system
oscillate at the TC's own resonant frequency. You can forward quote
this
Email on the 4HV list if you think it will help discussions there.
A pure Class E amplifier requires a net inductive load at the drain of
the
MOSFET. It is this lagging load current that actually drives the drain
voltage back down towards zero before the MOSFET is commanded to turn
back
on. If the load current doesn't have the required lagging component
the
drain capacitance wont get discharged quick enough and the drain
voltage
wont swing back down to zero in time for the device turning back on.
Therefore you either need to drive the Tesla Resonator at a frequency
somewhat higher than its resonant frequency, _OR_ use a matching
network
that provides an excess of inductive impedance to the MOSFET. Then the
drain will see the required inductive component in the load impedance
and
you can tune it for efficient Class E operation.
There is a Class E amplifier tuning guide here:
Cds is the total drain-source shunt capacitance across the MOSFET. Ls
and
Cs are the components of the series resonant components of the load
impedance presented to the MOSFET's drain. Zbase is the resistive
component
of the load impedance presented to the MOSFET's drain.
There are some pictures of my 8MHz Class E TC in that temp folder also.
I can't see myself ever subscribing to any more Tesla Mailing lists due
to
other comittments, but it is always interesting to see what others are
doing.
I think what he's saying is: You'll find it a hell of a lot easier to tune for a proper drain voltage waveform if you use a fixed oscillator to drive the system rather than a self-resonant driver.
The arrows on his tuning guide show which way the waveform will move when you adjust that given circuit constant. The object is to get the bit that the arrows come from to land at zero volts just as the FET switches on.
Dr. Shark
Sat Apr 08 2006, 05:39PM
Hey, thanks for getting some expert opinions for us here, but I think I am getting there anyway:
1144517744 75 FT6870 Dscn4130
this looks very much like the ZVS part of class E operation is happening as it should, now I need to fine-tune for ZCS. Before I do that, however, I suppose I should swap in a TC secondary that fits my resonant frequency. Since I lost most of the harmonics I had with my weird waveforms before, I am getting no more sparks. Oh, btw, the problem I had before was rather simple: The gate was not pulled to 0V quick enough and my dutycycle was about 90%. So I had to put in a small GDT to pull it negative, now it works nicely.
ragnar
Sun Apr 09 2006, 03:55AM
wrote ...
Hi BP..
I'm running at least 30kHz above resonance at ~720kHz. I think I should creep a little closer to fRes though.
I'm reducing the primary to a few turns and lowering the coupling by raising the secondary a little. What's delaying me at the moment is making a few PCBs for all this. My breadboard is highly inadequate - it seems I only need to wave my hand past and it all works, and I get waveforms akin to the underdamped one you see in Richie Burnett's tuning guide.
I'll also heatsink mr MOSFET and try 'real' input voltages. For now, everything was running from a 12V lead acid cell.
