  • Guests: 66
mileswaldron (59)
06/03 mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
How to fix the buzzing noise
Thu Sept 18 2008, 07:24PM Print
I found both my video card and the PSU in my pc emit a noise whenever the GPU is loaded. If the scene is simple ("press a key" screen in 3D game), it squeals a constant tone, also when minimising/maximising a 3D application. When I actually play the game, the noise emitted is more like a hiss and less noticable.
I got this idea, would winding one turn of the video card power cable (all wires) on a ferrite ring improve the noise, or is this asking for "inductive kickback" problems and possible damage to the GPU?
Bjørn
Thu Sept 18 2008, 07:39PM
Is this noise coming from your speakers or from the devices themselves?
Ferrite rings of the right type should not create any problems. If the signal is at the same frequency as the sounds you hear it is not a good idea to filter it out since it will cause the voltage to droop and possibly make the computer less stable. A modern PC needs a very good frequency response from the power suppply to work properly.
If the sound has not always been there it might be that you have some damaged capacitors on the graphics card or motherboard that causes more high frequency components to reach the PSU and creating more work for the regulators on the graphics card.
Thu Sept 18 2008, 07:58PM
Bjørn wrote ...
If the sound has not always been there it might be that you have some damaged capacitors on the graphics card or motherboard that causes more high frequency components to reach the PSU and creating more work for the regulators on the grpahics card.
The PC is new, it has been doing it since I built it, and yes, the sound comes from the components themselves smile
It's not really that annoying, when it's hissing it is barely audible. I'm not at all surprised it does this, as the GPU eats 100+W loaded, if it causes 10 amp surges on the 12V line, something might buzz...
I have a small ring that came with the case, I might try using that.
Edit: I'll also try my old PSU. I think I haven't heard the noise with the od PSU, but I've replaced it because it was noisy, so the buzz might have gotten lost in the noise of PSU and CPU fan (I also replaced the CPU heatsink so it's all super silent now cheesey )
Thu Sept 18 2008, 09:10PM
I had the exact same problem with one of my builds once. It was a PSU problem I remember. You can either get one rated for more power or that's better engineered. Alternatively you can fix it yourself. I found putting a mains input filter in the PSU halved the noise (no, it didn't have one installed stock. dead The required PCB traces, holes and component outlines were there though. ) I've also heard of people encasing the PSU magnetics in epoxy to limit mechanical movement, I'm not sure how effective this is however.
Thu Sept 18 2008, 09:25PM
Well, the PSU is of the quality ones, it's just not really that powerful (400W). I'm pretty sure it has all filters installed and the components are correctly rated. I bought that after reading reviews of the cheap crap that blows up with 2/3 of their power rating applied 8-o
But its wierd it also comes from the GPU, could a more powerful PSU fix also that?
I might also try to do a "mod" myself and put some low-ESR electrolytics and film decoupling caps near the GPU power connector...
Fri Sept 19 2008, 09:25AM
Do you get the noise in the computer audio as well? I remember that was the real problem I had, and now I can't remember if I really heard it from the components too.
Fri Sept 19 2008, 01:21PM
Uzzors wrote ...
I think the audio is fine. The video card draws its power from an extra connector so the high current does not pass through the mainboard and can't affect the audio chip.
Fri Sept 19 2008, 08:48PM
I just discovered a weird thing, there is a buzzer on the video card which seems to generate part of the noise for some reason.
Curiously enough, there is an unconnected jumper next to the buzzer, and even more curiously, this jumper is electrically connected to the buzzer terminals.
Theoretically, "jumping" this jumper will shut the buzzer up. Practically, do you think it is a safe thing do to? tongue
Ken M.
Fri Sept 19 2008, 09:06PM
Maybe, But first lemme ask, is your GFX card fan dirty from dust build up, even though you said its new? If there is dust build up, nad your GFX card can (and should be able to be removed) remove it! then remove the fan, most decent quality cards have 4 screws olding the fan to the sink. Once the fan is removed flip it over you SHOULd see a clamp clipped to the drive shaft of the fan, carefully pop off the clamp and slide the fan out of the hold. Inside the underside of the front of the fan you should se the fan bearing, lube it down with some wd40 or whatever you got thats similar, and clean out that bearing, put it all back together and that should solve your noise.
Sat Sept 20 2008, 07:22AM
I don't think the fan is the problem, there's no dust at all, and it makes the noise only under load (fan spins all the time). Thanks for the advice anyway.
Today I'm gonna measure the voltage on the buzzer and if it's more or less zero, I'll go ahead and short it out.
Edit: I shorted it and it still makes noise! suprised now THATs weird. Guess I'll have to cover it with something... (don't want to lose warranty by unsoldering it)
