  • Guests: 11
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
overlapped io under win32 confusion
Wedge
Wed Jun 04 2008, 12:35PM Print
Wedge Registered Member #315 Joined: Mon Mar 13 2006, 06:44AM
hi guys,
I'm a little confused maybe someone can help me out. It's about doing io over, say serial com port.
The code I have works, but I am not satified. I tried both, synchronous mode - polling für completion and sort of overlapped io...
I call it sort of, because what I did is set up a ReadFile() für some bytes and check the ovelapped status für pending in the same thread later in the code.
IF(!) I understand correctly it should be possible to 'hook' a custom windows message (or is it even a standard message?) to the io process to get get a call to the windows message loop automatically? Without knowing that I have to check the overlapped result? That would make handling io in a state-machine easier for me.
thanks
Wed Jun 04 2008, 01:04PM
The point of overlapped I/O is that you don't have to poll: the system will signal an event when your I/O is done, or even execute a callback function of your choice.
(Never used it myself, I just poll things)
