  • Guests: 39
Ben7 (29)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
java problem
scrooch
Tue May 20 2008, 11:33AM Print
scrooch Registered Member #908 Joined: Wed Jul 18 2007, 05:53AM
i have thefollowing class
public class person
public String name;
public String phone;
public String address;
public String email;
public person(String pname,String paddress,String pemail,String pphone) //constructor for the person class
name=pname;
phone=pphone;
address=paddress;
email=pemail;
and the following program
public class AddressBook
public static void main(String[] args)
ArrayList<person> people = new ArrayList<person>();
people.add(new person(tname,taddress,temail,tphone));
public static void addperson(String data)
people.add(new person(name,address,email,finalphone));
when i try to compile this is gives the following error in the line people.add(new person(name,address,email,finalphone)); in the addperson method
Error: cannot find symbol
symbol : variable people
hod do i fix this?
Dago
Tue May 20 2008, 12:09PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
I think theres something wrong with your variable "people" declaration.
Shouldnt it be more like: people = ArrayList(person);? But I still think you cant give a class named "person" as a collection for the ArrayList function which requires a collection but I'm not sure about this since theres alot of time since I used java.
Tue May 20 2008, 12:26PM
I think this is a scoping issue. You declared the "people" array in main. It probably isn't visible from within your addperson method.
I think the declaration of the people array is fine as far as its syntax. I guess <person> is a template that specifies that you want your ArrayList to contain "person" objects.
If I were writing this program, I'd give addperson() an extra argument, that specified the array that you want the person added to. YMMV though: I'm a C++ guy and have never used Java. It's like Sun made a new language out of all the worst parts from C++ and all the worst parts of Visual Basic ill
