  • Guests: 29
Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
Resurrect a 28" TFT monitor.
Sat Mar 15 2008, 08:58PM Print
Hi all.
I have two of these left, both of which have fried power supplies but the PCB and panel seem to be intact.
It might be an interesting project to attempt to build a replacement using a PC power supply.
Required voltages and currents:- 5V at approx 2A, 12V at 2.5A, 24V at 4.5A (backlight PSU)
Any ideas? I once did this using 8 PSU's paralleled and it worked for a while until correct PSU was procured off Ebay.
I also have a Samsung 22" panel which needs 120V, panel turned out to be bad but the power supply is OK. Any chance it can be modified to run off 240 with a minimum of modification?
Regards, -A
