  • Guests: 17
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
new multi spark gap idea
teslacoolguy
Sun Nov 11 2007, 03:47PM Print
I was brainstorming some ways on how to make a simple multi spark gap. I came up with the idea of yousing like 4 sparkplugs in a series at lets say 1mm per gap that would make a 1-4mm spark gap. You think it is a good idea?
Zum Beispiel
Sun Nov 11 2007, 05:34PM
I think it has been done before... If you try it, remember to get plugs with no internal resistor. Would brobably work on a small coil.
Kizmo
Sun Nov 11 2007, 07:24PM
I made spark gap from two spark plugs. I did it little differently, i lathed outer electrode and almost all of the thread away to reveal ceramic insulator enough. It works very well and can take huge loads of power like tungsten rods. Center electrode of plugs is tungsten or something similar.
If you do this, you have to use new and clean high quality plugs!
1194808838 599 FT34037 Sg
Mon Nov 12 2007, 06:27AM
If you look around ebay you can usually find 1/4" diameter pure tungsten rods that are fairly affordable,
I think they're excellent.
