  • Guests: 17
BlakFyre (36)
SENTRY (31)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
SSTC questions
1 2 3 4  last
Dr. H.
Sun Sept 23 2007, 08:19PM Print
After the Micro SSTC 1 i decided to build something bigger. So i decideded to use this circuit http://www.ctc-labs.de/html/micro_sstc_2.html .
I was wondering is there anything that must be changed/added to the circuit. I saw a little error - the full wave rectifier on the 12v supply is connected wrong. Also i was wondereng should be there any snubber capacitor across the half bridge or this function is done by the two capacitor connected in series.
Tommorow i will post some pics on my progress.
Huben smile
Dr. H.
Sun Sept 30 2007, 06:50PM
**Update **
So i finshed the circuit board and hook it up to test it. The cd4046 is generating a square wave (without secondary and antena) about 600khz when the tuning pot is fully counte-clockwise. So hire is the question - when i turn the pot (10k one on the circuit) the frequency starts to change - aqtualy decrizes to about 450khz when the pot is fully clockwise. Is this normal, because i think that this shoud change the phase not the frequency ?
The other problem is with my driver chips - the waveform that i get on the otput of the transformer is more like sinusoidal rather than square weve, but i hope that this will change with the tc4420s (now i was using ICL7667 witch are 2x1.5A each )
Hire some pictures, please comment any flows in my layout and excuse my english rolleyes
1191178241 931 FT31805 Pic 4344
1191178241 931 FT31805 Pic 4345
Dr. H.
Mon Oct 01 2007, 03:03PM
Why no one is answering. Am i so booring or my questions are dum cry
EDY19
Mon Oct 01 2007, 03:59PM
Its nothing about you, and I would attempt to answer, but I've got no experience with PLL circuits- however, your circuit board design looks very nice for a protoboard!
sehrgut
Mon Oct 01 2007, 05:37PM
sehrgut Registered Member #1017 Joined: Fri Sept 21 2007, 09:08PM
I'd answer too, if I'd ever built an SSTC before! I've been working in a rather Luddite mode for the last few years as far as technology goes, so I haven't touched anything with IGBTs or big MOSFETs. Your driver does look luvverly, however! *grin*
Don't feel bad . . . no one's answered my OBIT filtering question either . . . *sniffle*
Dr. H.
Mon Oct 01 2007, 06:03PM
Thanks for the repplyes guys smile
So todday i received the drive ICs (TC4420). I put them in and tried them. The traces on the scope didn't look very good at all angry . They are better from the ones with the ICL7667 but i don't think they will lork neutral .
Mon Oct 01 2007, 06:08PM
Where's the antenna?
Dr. H.
Mon Oct 01 2007, 06:11PM
So hire are the traces. They are the gate - source signals. The top one is with 2 ICs (like on the schematic) and the bottom one is with 4 ICs (2 in paralel). The scope is set to 0.5 micro seconds/div and 10V/div. So what do you think about them ???
1191262254 931 FT31805 Pic 4347
1191262254 931 FT31805 Pic 4346
Zum Beispiel
Mon Oct 01 2007, 06:21PM
Those scope shots look fine. You could have a bit faster rise and fall times, though. Some beefier drivers should help with this. Won't probably be a problem tough.
What FETs are you using?
Dr. H.
Mon Oct 01 2007, 08:09PM
The fets are IRF740 - half bridge. Shoud i use 4 or go with 2 drivers. I was concerned about the loses at this high speeds
Dalus - this is cd4046 generating in the moment without the antena (i will add it later when everything is set ) The frequency of the secondary is about 450khz so there will be not a big difference - i think wink .
Also when i use 2 drivers they get a bit warm - i suppose this is OK - wright ? rolleyes
1 2 3 4  last
