  • Guests: 14
BlakFyre (36)
SENTRY (31)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
really quick simple question -- steve wards micro sstc
teslaguy
Sun Sept 02 2007, 08:42AM Print
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
I just ordered the parts for it and i was wondering if it would be safe to run the mosfet off of reguated line voltage instead of the 35vdc? i have some bigger mofsets on hand to so i might try to switch a newer one in to. Would I be safe with line voltage or do i need bigger r3? Link2 is the circuit for reference
thanks much.
Sun Sept 02 2007, 10:20AM
Do you mean "line" as in 120V AC from a wall socket? If so, that's probably not a good idea as the voltage across the MOSFET can be several times the supply voltage (at least 3 times) so the 160V DC you get from rectifying the line could possibly blow a 600V MOSFET. Step it down with a transformer out of an old stereo or something. This also isolates the whole mess from the line and reduces your chances of getting fried.
