  • Guests: 23
BlakFyre (36)
SENTRY (31)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
280 Watt Flyback Driven Tesla Coil
Bauerb2
Sat Sept 01 2007, 05:07AM Print
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
I have seen many attempts out there to build a flyback driven tesla coil, and i've seen some good ones and some bad. But anyway, i would like to show you all my 2nd flyback driven coil.
Specs:
Half-bridge flyback driver from scopeboy.com http://www.scopeboy.com/tesla/flyback.html
-IRFP250s, 555 driven
-9-10 turn primary on flyback
Adjustable 0-12V RSG made from wood, bolts, plexiglass, and a motor.
4x 590pF primary tank 30kV
Tapped 8-9 turn primary.
1-1/8"dia 6" tall sec (not sure of the wire gauge, from iron core transformer)
2" dia sphere topload, no breakout
Control 'box' containing 12v drive voltage for FB driver, 30V 'high' voltage for FB primary xformer w/ FW rectifier, rotary spark gap speed control.
It doesnt seem like much, but this coil works great. Average streamer length with no ground target: ~5" Average arc length to a ground: ~7-8"
enough of that here are some pics. Enjoy...
1188622034 973 FT0 Sd530037sml
1188622034 973 FT0 Sd530038
1188622034 973 FT0 Sd530040
1188622034 973 FT0 Sd530040d
1188622034 973 FT0 Sd530041
1188622213 973 FT0 Tcmoon 002
and of course, a video http://www.youtube.com/watch?v=xUpGH7kSeFs (video's a bit old, new secondary (red) = longer arcs)
This type of coil can be made, honestly, with junk. i spent maybe $25 on this whole project (only bought caps, mosfets, circuit board.) This is a great project i've worked on, and i would like to know if i can improve this anymore. Any comments?
ShawnLG
Sat Sept 01 2007, 06:31AM
That is the best flyback powered TC I have ever seen. Good job!
Coronafix
Sat Sept 01 2007, 06:35AM
I second that motion!
It must be the rotary spark gap that makes it
so good.
Well done.
Sat Sept 01 2007, 09:21AM
I third it, excellent cheesey
colin heath
Sun Sept 02 2007, 11:11AM
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
I have to agree with everyone else!!! What a great coil. I haven't seen such a small coil with such power.
That rotary gap really makes the coil sing and the streamers are very bright.
Cheers
Colin
Marko
Sun Sept 02 2007, 11:31AM
Beautiful little coil, and I must agree with Shawn, one of best-performing too.
Really don't know.. except you could maybe box the coil up? I think it really deserves..
Mon Sept 03 2007, 09:20AM
Nice job, I'm also trying to make a flyback TC but the results are poor...
