  • Guests: 8
Shaun (34)
Spedy (30)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
Tesla coil new comer
Josh
Sat Aug 04 2007, 05:51AM Print
Josh Registered Member #938 Joined: Sat Aug 04 2007, 05:39AM
Okay years back I was seeing this forum found it again and now want to
build a tc now. I have some bassic tc knowledge but am lost. I am looking
for a very easy and bassic website for a small tc that could creat arks but
nothing big. So I need a nst so that tells the size of the tc but could you
give me a site that uses a ignition coil tc instead because I could get a
few of them easy. Well any ways
Thanks,
Joshua Martin
ShawnLG
Sat Aug 04 2007, 05:57AM
Google can work for your quest on building your first TC. There is always the 4HV Wiki.
Josh
Sat Aug 04 2007, 09:22PM
Okay thanks 'll look,
I am too frusterated about getting
a old enough flyback since I burned my
last one out.
CT2
Sun Aug 05 2007, 01:43AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
If you wan't to make a tesla coil with a flyback you can't use the older style AC ones, unless you rectify it. You need to use the modern DC ones or rectify your old AC one. I forget where it is but someone on this forum made a really nice tesla coil from a new flyback (if i remember right), and housed in a wooden box it looked damn good. So just look around because there is plenty of examples and help out there.
Josh
Sun Aug 05 2007, 03:49AM
Okay just a day ago I had a modern one but could only get 5 mm arks,
I used the old board and the resistors got really hot but I got mad
about the thing not putting much out even after I removed the diode,then I
tossed it. I am thinking about a ignition coil tc but I want to use a circuit that
uses a relay to drive it along with a capaciter could someone point me in the right direction ? I think I could use an ignition coil in the place of a flyback then I would just need to pop open a microwave then remove the diodes to rectifie the power source.
Thanks for the help/tips amazed
Mon Aug 06 2007, 11:23AM
Google is your friend, 15 seconds of my time Link2
EDY19
Mon Aug 06 2007, 03:28PM
I would really steer away from a relay- a single mosfet would do much better in my opinion, as you don't have to worry about contact wear- and if designed properly, it would be much more reliable/predictable. Even a 555 driving a single mosfet would be an improvement over a relay. Just know that the primary of an Ignition coil has a very low resistance, so peak currents are gonna be pretty high, higher than many relays would like to see.
Josh
Tue Aug 07 2007, 01:08AM
Okay I will use a switch I have lying around frie that then use a mosfet that is high voltage rated with a 555.
Thanks for the help cheesey
