  • Guests: 15
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
SGTC coming together
Sun Jul 22 2007, 11:14PM Print
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
So I am in the final assembly phase of my coil....
Coil2
So I have some more to work on... main concern is I won't be able to get a decent spark from just 9 turns on the primary.... I'll probably run some more copper tube in and solder it all together. I can put 14 turns in my current coil form.
Primaryform
It's 1/2" HDPE (cutting board). the top strip and the bottom part are held together with nylon thumb screws, the coil lays in loose on the form, but the top (cap?) holds everything in place really well, so I'm happy with that.
Here is my toroid:
Toroid
Detail
Does that look spark worthy?? I used a lot of Aluminum tape and I'm concerned about the adhesive and layers of tape building up some weird stray capacitance - can that happen?
Any other advice, critique, comments, suggestions are greatly appreciated and welcomed.
The insides are:
12/30 NST with a static spark gap (ATM just a single gap, making a blown multi-gap soon) I've got a terry filter and a CDE 942 based MMC I needed to work with it... .01uF / 30kv.
all my pics are in: Link2
thanks for the help and inspiration - first light pics soon :)
-Doug
