  • Guests: 21
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
a PIC based capacitor charger
Thomas
Fri Jul 13 2007, 06:17PM Print
Thomas Registered Member #120 Joined: Fri Feb 10 2006, 07:07AM
I'm posting this just to ask if my idea is a good. Basically I'm very new to PIC programming and wanted to keep the programming down a bit. So what I would like to do is set a voltage with a keypad (not a big deal) and the charge the bank to that set voltage or drop the current voltage to the set voltage. A high power boost converter will be used.
Now here is the part I question. I currently have a circuit with the TC14433A IC being used. This is a ADC, where the typical application is a voltmeter (this ADC displays 3 1/2 BCD digits (1.xxx or 0.xxx) -> (0 to 1.999mV)).
Now should I just send them to the PIC or should I code a 3 1/2 BCD digit voltmeter myself?
Also can anyone please suggest a few good books? Would it be better to use the PIC ADC and make it into a 3 1/2 BCD meter? Also I'm using the PIC16F877A.
Fri Jul 13 2007, 07:01PM
Probably you best bet would better off with integrated a/d, and drive the displays from the pic. I have a feeling that trying to decode the bcd output from the a/d will be tricky... I think that the 16f877 only has 8bit a/d, but if you can manage with 2v/count (ie, 0x00=0v, 0x01=2v,...0xFF=512v) you should be fine.
Thomas
Fri Jul 13 2007, 07:23PM
... wrote ...
See the problem is that the max voltage is 1200V so I would need 11 bits. I think BCD would be my only option unless I could use a 12 bit or more PIC, but they don't make them from what I know (I'm using microchips line) and I think the programming might be too complicated since I'm a beginner. I have made 3 BCD digit counters though. Thanks for the input
Wolfram
Fri Jul 13 2007, 07:35PM
The ADC is 10 bits. Some 18F-series PICs have 12 bit ADCs, some 16F ones might as well. This means that you'll have a volt resolution if you set your max charging voltage to 1000V or half a volt if you set.
Using the PIC ADC is exceedingly simple. You put the right A/D configuration in ADCON0 and ADCON1, set the GO bit, and a short time later, the AD_GO bit goes low again and the result is in ADRESH:ADRESL.
An example. ADCON0 = b'01000001' (A/D clk = Fosc/8, ch. 0 selected, A/D on), ADCON1 = b'10001110 (right justified result, RA0 = analog input, the rest of the port is digital). Remember to configure RA0 as an input!
bsf	ADCON0,GO
LOOP	btfsc	ADCON0,GO	;Until GO is cleared (conversion finished)
	goto	LOOP		;Then wait inside this infinite loop
I recommend switching over to the 18F series PICs. The instruction set is similar enough, so there's not very much you need to learn if you already know 16F assembly. Most of the small annoyances of the 16F series are fixed, you don't have to deal with the pages in RAM or ROM. There are also many improvements, like multiply instructions, heavily improved indirect addressing, port latch registers in addition to the port registers (no more read-modify-write problems when using RMW-instructions on the ports).
Thomas
Fri Jul 13 2007, 08:12PM
If I do go your way I found a nice chip with a 12 bit A/D, either the PIC18LF4423 or the PIC18LF4523. I think i will try to make a little program with your example and go though microchips documentation again and see what I can do. Now I can't seem to think of it now, but would there be a way to isolate the sample voltage? I'm currently using a voltage divider in my circuit to divide the voltage by 1000 so I have a sample voltage of 0 - 1.2V instead of 0 - 1200V. Do they make opto-isolators that if I send a volt in a get a volt out and if I send a half a volt in a get a half of a volt out? could that be done with a normal phototransistor by sending the voltage to the diode (never tried)? I don't see why it wouldn't work since i'm eith increasing or decreasing the light that hits the base of the transistor. Unless they don't work that way and are either on or off.
Wolfram
Fri Jul 13 2007, 08:50PM
Yes, TI (Burr brown) have some voltage isolators, but they cost more than you want to know.
How about a PIC on the high side, sending digital data (RS232 or whatever) through an optocoupler to a PIC on the low side.
If you're programming it in assembly, feel free to PM me for help, I can't guarantee that I can answer all your questions, but I can try.
Anders M.
Avalanche
Fri Jul 13 2007, 09:26PM
Have a look at the LM331, it's a voltage to frequency converter that can provide simple a2d isolation through an opto-isolator. You can then use the pic to measure the frequency (using a pin set to 'interrupt-on-change') or just measure the pulse width to determine the voltage.
Simon
Sat Jul 14 2007, 12:43AM
Thomas wrote ...
Not necessarily. You'd be using a voltage divider to drop the voltage, right? It all depends on how much resolution and range you need.
Do you need it to know exactly what the voltage is if the voltage is below 300V? Or does that just mean you need to charge up?
Do you need 1V increments, or is the nearest 4V enough?
Thomas
Sat Jul 14 2007, 06:54AM
Anders M. wrote ...
Anders M.
I think I'll go your way with a PIC18F2523. This chip has a 12 bit ADC module onboard so I can for sure get a xxxx resolution on it (between 0 - 1200). Then I would just send the date serially to the PIC16F877A in BCD formate (of course first converting to the 12 bits to 4 BCD digits). That way I would only have to isolate one line.
Also just to add if under 300V is entered I detach the 300 supply from the boost converter via relay and then bleed the bank till it reaches the voltage. Then if needed it will reengage the relay (connecting the circuit) to add a little more voltage and if more then 300V is added it activates the FET on the boost converter (enable pin on mosfet driver set by yet another phototransistor). I guess things will be turning on and off a lot cheesey I plan on using a solid state relay to alleviate me of the relay clicking sounds.
This should be a fun summer project I guess I will update my circuit now.
I found the TC14433 chip to be pretty cool though.
My other goal here is to have two circuits that are 100% isolated from one another. I want to make the user operated side detached from the capacitor dangerous side.
Thanks again everyone, I now feel much more confident in my design!
Thomas
Sun Aug 12 2007, 03:59AM
I'm just about finished with the circuit boards (using express pcb) however I just realized that I might have a problem, since i'm isolating a chip that does serial communication. I have a feeling that my phototransistor might see fast clock speeds. But i'm not sure on how serial communication works. I'm driving my chips at 16MHz. Now I have a master and a slave since i'm using the most basic method (SPI).
My questions:
Now the clock for SPI goes in one direction from the master to the slave right? Also how fast would it's actual clock speed be? Those are just two of the things i don't know. Other wise the masters input connects to the slaves input and the masters output connects to the slaves input, no big deal there.
Thanks all!
