  • Guests: 27
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Tesla Envy - the video.
Tesladownunder
Thu Jun 28 2007, 06:15PM Print
My latest video. YouTube 1:43 mins
TDU
Thu Jun 28 2007, 08:33PM
You are one cool dude, man!
Cheers, Finn Hammer
Sparrow338
Fri Jun 29 2007, 05:58AM
Sparrow338 Registered Member #661 Joined: Sat Apr 21 2007, 03:17AM
Very cool, nice video!
sparky
Fri Jun 29 2007, 07:39AM
wow! So you are using a small PT for your power source? Very very nice! nice sparks!
Tesladownunder
Fri Jun 29 2007, 07:49AM
I'm not sure what the transformers are but around the 10kV each suggests a PT. I found these two in a transformer bin in a junkyard and got them for the scrap iron/copper weight. They had some much larger multi pancake transformers but sadly too large.
The coil is only firing at about 5 feet sparks in this photo because I gave my son a limit. Nevertheless it should do much better than the 8ft best so far. I haven't put it through JavaTC because that won't run on my computer.
TDU
kv
Fri Jun 29 2007, 08:36AM
kv Registered Member #809 Joined: Wed May 30 2007, 08:59AM
very cool!!! was the cage you were standing in glowing red hot at the end?
Tesladownunder
Fri Jun 29 2007, 10:33AM
The cage wasn't hot but the chainmail glove is earthed by 2 separate bolts. These were standard steel bolts but got hot enough with the RF losses to give me a slight thermal burn.
The welding type sparks are from some steel wool on the ends of all the spark contact points.
TDU
sparky
Fri Jun 29 2007, 03:05PM
How many KVA are these trannies rated at? Curious.... who makes them?
Firnagzen
Sat Jun 30 2007, 04:16AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
Good grief. Nice stunt! Also, is it just my eyes, or when you were using the dalek cage, were there streamers coming off the cage itself? I watched the video a couple of times and I'm pretty sure I saw something like that.
the_anomaly
Sat Jun 30 2007, 04:38AM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
I love the part where you pray to the tesla god and the new coil appears. When your in the cage it seems you look directly into the spark, how bright is it?
