  • Guests: 19
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
mini SG Tesla coil
Danielle
Fri Jun 22 2007, 07:14PM Print
I worked on a small SGTC and I finished it but the performance isn't that great. here are some pics its driven by a fly back transformer.
1182539650 632 FT0 Img 0289
1182539650 632 FT0 Img 0290
1182539650 632 FT0 Img 0295
1182539650 632 FT0 Img 0297
Never mind I got a 1/2" sparks to the air from the brake out point I just needed 2 more windings Ill post pics tonight when the lighting is better also what is the best way to take pictures so faint sparks?
Sparrow338
Tue Jun 26 2007, 02:42AM
Sparrow338 Registered Member #661 Joined: Sat Apr 21 2007, 03:17AM
Looks cool. What are its dimensions and the size of its tank cap? Depending on the size I bet you could get a lot more out of it. Here's one I made. http://www.youtube.com/watch?v=JEuv6GAEnVE Its secondary is about an inch in dia. by around 8-9 inches tall. (not that great of an aspect ratio) It puts out streamers from a break out point that are around 5-6 inches and with more power sent to the flyback I can get upto about 8. But anyways, do you have any other specs on it?
Danielle
Tue Jun 26 2007, 03:02AM
yah it is 1" dia and 5" tall the tank cap is .0056 uf and I have 7 turns on primary.
sparky
Tue Jun 26 2007, 04:56AM
Increase the number of primary turns... then see if the output changes. I bet it will be MUCH better :)
Tue Jun 26 2007, 11:02AM
It probably just needs tuning. Also when the sparks are wimpy and long like that the spark gap is too wide. I found I had to use tight coupling and high BPS to get good streamers from my tiny coil. Link2
Danielle
Wed Jun 27 2007, 04:35AM
ok so I totaly screwed up and now I fixed it the coil will pout out 6" long streamers (as long as the coil) but you can only see 3" on the camera. here are some pics this coil is defently a keeper. cheesey
1182918926 632 FT27288 Img 0333
1182918926 632 FT27288 Img 0344
[link]
Sparrow338
Wed Jun 27 2007, 05:37AM
Looks great! Your spark length, at least spark lenght to coil size, is beating my mini coil. ;)
I got some questions for ya too. :)
What driver do you have running the flyback? If it's ZVS what voltage/amperage(if you have a way of metering it) are you putting into the flyback? Also are you running a DC flyback or an AC one? Also what guage wire are you using?
BTW: For taking pictures you can try first making sure that the camera's flash is off, the shutter rate (ISO) is set low, and that your room lighting is also low. Usually camera's have a manual mode that allows you to change these options.
Keep up the good work! smile
Danielle
Wed Jun 27 2007, 06:05AM
ok so I am using a ZVS PSU and I am running it at 47V at 6A and I have 7 turns on each leg so 14 total. The flyback is a DC flyback but I thought it was an AC one because it didnt have a filter cap so only one I hoocked it up I realized how good this one was. I will build a new deiver with this center taped because I have 4 of them and I can buy 40 of them for $4 each at the stor I go to. the wite I was using was 16AWG and everything was getting hot espeacially the IGBTs but when I added a fan I cooled everything down verry well. Last thing is tha this is verry cool it defently is a huge improvement and I added 3 more turns and the spark length increased even more.
Danielle
Thu Jun 28 2007, 01:38AM
ok so now I have some even better pics it still doesn't do justice.
I just love this pic cheesey
1182994688 632 FT27288 Img 0348
1182994688 632 FT27288 Img 0345
Shaun
Thu Jun 28 2007, 01:46AM
Awesome coil, looks very well put together. What is your primary made of? It almost looks like thick solder.
and lol, typing skills and tesla skills must be in two different parts of the brain. wink
