Registered Member #96
Hi all. This one has been bugging me for a while. For some stupid reason every single cheap soldering iron I have owned, be it iron-over-brass or iron-over copper has failed due to bit erosion.
I have found a way to effectively replate them however.
Obtain a surplus ball point pen, some steel wool, bicarbonate of soda, syringe/needle and soldering iron bit.
Get 100ml of water (ideally deionised) and stir in as much bicarbonate of soda (NaHCO3) as will dissolve. I used one teaspoon.
Sand the bit and/or shape to correct form to remove SMDs etc then clean it with isopropanol. Then, get your ball point pen, cut off a 1" section of the barrel and stuff it with steel wool up to the end. Use the syringe and needle to inject the bicarbonate solution until the wool is saturated.
Poke a small hole in the top of the pen, and insert a multimeter electrode. The other end of the multimeter connects to the positive side of a constant current supply with a maximum voltage of around 12-15V.
Connect the soldering iron bit to the ground side. Adjust the constant current supply so that the iron bit is *just* bubbling, too high and it may not correctly plate. 0.3A on mine.
You will need to leave the setup at least an hour to plate properly, I recommend removing it after half an hour and gently abrade the plating with a tissue to get rid of any debris.
Registered Member #56
Hmm, I usually just dremel down the tip and go from there. The tips I use are generally solid brass, sometimes I need to add a little flux but I have never had problems with getting the tip tinned.
Registered Member #63
I've seen some nifty 'rejuvenator' products which are only recently sold at a store where I work. They seem to be just flux and tin, though. GOOT brand, so they can't be too bad, right?
Banned on 02/27/2008 Registered Member #1326
Your description does not tell what metal is being plated on the copper and what is the anode and what is the cathode.
Conundrum wrote ...
